Kyosho FW-05R
#4186
Moderator
Tower has the 39T but its insanely expensive there, if you order from HK its like 38$ per set.
#4188
Location: batang kalokohan! ay kaloocan pala!!diretso ka lang,pag nasaksak ka! bahay na namin yung sa harap!
39t
i have mine 1st 22/50 and 2nd 29(mugen)/45 and 39t ring gear,it runs great,perfect power on bottom and lots of top end,great pick up too on middle power.
#4189
Re: 39t
#4190
Re: Re: 39t
Originally posted by InitialD
Of course with a 2nd gear FDR of 4.65 you'll have enough top end !
#4191
Hi!
I am wondering what the weight of the blue aluminium swing shafts is? Do they have an equal length? The steel-shafts supplied with the S-kit have a longer shaft in the front and the shorter one in the rear of the center drive. Now i saw some people using these shafts in the rear (in combination with rubber tires and a standard GS-15R pullstart-motor (kwc expert)). Even if they weight less they should have more mass more far away from the rotational center because they are thicker? Any ideas about the pins popping out the drives when racing hard?
Has anyone experiences with the 3racing titanium hinge pins for the FW-05RR? Smooth finish and good precision (exact 3mm diameter)? What about the durability?
Regards,
Robert
Regards,
Robert
#4193
Would you happen to have a list of the Kyosho parts you carry?
If you don't find what you want there email [email protected]. This is my boss at the hobby shop and he can get you what ever you want for kyosho. Or you can give me a call at the shop after 3pm E time. 757-361-6681
keith
#4194
Super Moderator
Re: associated springs didnt fit ??
Originally posted by mrgsr
hello
i posted on here about a week ago asking if the assocaited spring set for the ntc3 fit and i was told that they did.
the springs fit over the shock but not onto the shock collar
can anything be done about this ?
thanks
hello
thanks
Thanks to Jeffreylin
#4195
Moderator
Someone was asking about the quality of 3R's Titanium hinge pins.
Well I just got a set of front Kyosho pins that cost just for them more than the entire 3R set, adn the Kyosho set is NOT ROUND!
One of them is oval shape and the other has a ripple down it.
3R's have to be better than this, and costs WAY less.
#4196
New 3r Gearbox fitted
#4197
Moderator
Nimo what pivot ball hex cap screws you using? got a place where I can score a set? the stock plastic ones suck (bind too easy going lock to lock)
#4200
They look like the old GP spider springs. They come in a set of six, 2 orange, 2 green, 2 yellow
