T.O.P. Racing "Scythe" 1/10 EP Touring Car >
Old 06-26-2008, 10:07 AM
  #1081
MikeR's Avatar
Trader Rating: 15 (100%+)
Who carries the parts in the US, specifically the steering parts? Google is bringing up Kenon RC but they don't list any parts...
Thx,
Mike
MikeR is offline
Old 06-26-2008, 10:10 AM
  #1082
yokemad's Avatar
Originally Posted by yokemad
Hi Guys
I've got the red scythe as a second car next to my Mi3
I usually put the car on setup board to sort out Tweak, I've tried that with Scythe but m3 screw heads touches to setup board before the chassis because of that it plays left to right on setup board behaves like its tweaked ...
Have you guys have that type of problem?
what you suggest me to do?
Thanx in advance
Up up
try racing11.net mate
yokemad is offline
Old 06-26-2008, 10:28 AM
  #1083
I put 2 blocks of my Hudy setup set under it.
Between the weels.
mikky32 is offline
Old 06-26-2008, 11:20 AM
  #1084
odpurple's Avatar
Thx,
Mike
TOP Racing USA [email protected]
Ampdraw Hobbies www.ampdraw.com
odpurple is offline
Old 06-26-2008, 11:56 AM
  #1085
MikeR's Avatar
Thanks guys!
MikeR is offline
Old 06-27-2008, 11:26 AM
  #1086
razzor's Avatar
Any news and feed back from teh ROAR Nats ???
razzor is offline
Old 06-27-2008, 12:13 PM
  #1087
SORRY FOR THE DELAY ON THE NATS GUYS I QUALIFIED 8TH AND FINISHED 10TH IN STOCK KYLE BERGSTROM QUALIFIED 6TH AND FINISHED 3RD IN SUPERSTOCK AND JOSH CYRUL QUALIFIED 8TH IN SUPERSTOCK AND MOD AND I BELIEVE HE FINISHED 4TH IN EACH CLASS SO NOT A BAD WEEKEND AGAIN FOR THE T.O.P. TEAM
ERTRACHTER is offline
Old 06-27-2008, 12:25 PM
  #1088
John Tag's Avatar
Trader Rating: 42 (100%+)
Great runs this weekend Jason.. Always in the hunt to no supprise..
You got a PM..THX......
John Tag is offline
Old 06-28-2008, 08:47 AM
  #1089
STLNLST's Avatar
Trader Rating: 32 (100%+)
you coming up for the speedworld cup?
STLNLST is offline
Old 07-02-2008, 11:48 AM
  #1090
TOP is working on a new 1:10 car and a 1:12 scale car.
Now i can't wait till i see the new cars and as they make the 1:12 so good as the TOP Scythe than i want it.
mikky32 is offline
Old 07-02-2008, 12:13 PM
  #1091
Hello, this past weekend i run Nationals, with my new "TOP" car ,only can classified for final C, with only 2 heats run, because my car have a lot of tweak, and i don´t know why ,changed the Top deck, new and cut, a new chassis, 2.5 mm US, new servo, loose screws,...etc, and the car never run straight, always turn to left hand, and hold this position, more dificult to drive.
i need some advices, to solve the problem.
The car run very good, some short times, more fast, 2 or 3 laps, i run with all alu parts, without the front post.
I get the feeling that the top deck is short, ¿...?
Congratulations ERTRACHTER , is possible to know the setups.
Greetings, Luis C.
luic is offline
Old 07-02-2008, 12:45 PM
  #1092
razzor's Avatar
Cool news bud
Look forward to it .
razzor is offline
Old 07-02-2008, 12:46 PM
  #1093
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Greetings, Luis C.
Hola Luis,
chequea que todos los shocks tengan el mismo rebote y compresion, y que todos tengan el mismo largo. Tambien pon el carro en tweak station y esegurate que este bien balanciado.
Prueba el carro- debe correr derechito como una flecha...si sigue con los mismos problemas, entonces es un problema mas serio.
yyhayyim is offline
Old 07-02-2008, 01:28 PM
  #1094
sosidge's Avatar
Try the car plastic.
Also, check that your servo saver is not sloppy, a bad servo saver will make the car drift to the side.
If the bottom deck of the chassis is flat and all the parts are moving freely there is no reason why you should suffer from any tweak.
sosidge is offline
Old 07-02-2008, 03:16 PM
  #1095
Thank you very much, for the fast replys, now i know because some guys make a TQ easy, training write fast in rctech..
All shocks, parts, servo saver, etc... are testing, i test all four tyres touch the floor at the same time, before run the car, run well 2 or 3 first laps, only.
The only part i suspect, is the top deck, the bottom deck is flat, but when thigten the screws of the top deck, the bottom is bends upward.
i have the delrin spool, and after de race, i cheked it and have a lot of play, this is possible another problem.
Muchas Gracias, yyhayyim, ya probe todo esto y seguia igual, este finde lo testeare un poco mas, a ver si soluciono el problema.
Greetings, Luis C.
luic is offline
