Serpent 710
Old 01-07-2004, 02:21 PM
  #2761
Tech Prophet
InitialD's Avatar
Originally posted by fmolzer
Shame on you for expressing your opinions and giving advise to your poor fellow racers.
No worries. As long as the paycheck from Serpent comes in, I'm happy !
I've been gone for a while, so my 710 is just nearing completion... Will be interesting to see what it does on the track.
How terribly inefficient ! Look at Andrew your mate ! He puts you to shame !
Let us know your feedback too once you get it on track. Don't wanna let people complain that only a few here are giving feedbacks !
InitialD is offline
Old 01-07-2004, 02:51 PM
  #2762
Tech Prophet
InitialD's Avatar
Originally posted by crashed_1
Can you post a pic of your shortened flyweights?..or which area of the flyweights did you shorten?....THANX.
Ok, this is a clearer picture of what and how it is done. I took the opportunity to take pictures when I mounted a spare Centax III clutch onto a spare engine. That's why it's clean and nice.
Please note that this is not a Serpent sanctioned mod and will not take any responsibility if anything bad happens. It worked wonderful for me and for Jack too.
Top flyweight is modded. Bottom is original and shows approximately where and how much you need to cut.
After the 3 flyweights are shortened, install it like this on the flywheel. They sit in nicely.
InitialD is offline
Old 01-07-2004, 03:18 PM
  #2763
Tech Prophet
InitialD's Avatar
Originally posted by fastharry
thanks Profi......
let me ask you this.....When you need to get the front midshaft out.......and the rear 2 sp shaft..(for changing belts on each end)..
How easy is that to do?......We were comparing this car to the r40 as far as ease of maintenance...And not for anything,you can both belts changed in a r40 in a few minutes....
In case, I get into trouble again, I'm not Proficar403.
This is the front midshaft. Notice that the pulleys (19T and 22T) are located at the sides of the front midshaft. The front belt can slip sideways into the mid 19T pulley as it is not restricted by the mid bearing block like can be found on the 705 / Impulse design. Is the R40 the same?
This is the rear side where the 2 speed layshaft sits. There are only 3 screws holding the left rear bulkhead from the bottom of the chassis (not shown). You can access or mount the rear belt on the 24T brake pulley by first taking out just one screw on the carbon fibre brake bracket (802303) that attaches to the left side rear bulkhead. Unscrew the left side tensioner screw to the left rear bulkhead. Unscrew and release the 22T rear side layshaft pulley and you can access the 24T brake pulley already by sliding out the left rear bulkhead.
Well, after all being said, if at the end of the day the R40 can do 2 minutes faster than the 710 in changing belts, what's the point? As far as I can remember, there are no trophies for the fastest belt changer !
InitialD is offline
Old 01-07-2004, 04:22 PM
  #2764
Racing4Evo's Avatar
Saw a sponsored driver with the car and man was it fast! It corners so flat. I must resist getting one.
Racing4Evo is offline
Old 01-07-2004, 04:51 PM
  #2765
Arun's Avatar
The greatest thing for me about this new system is being able to remove the rear diff easily. Many of the old 705 forum members know how much I like that ability .
Another thing...about changing belts quick...is that I cannot remember ever having to change the rear belt on my impulse or 705, especially quickly. The front belt...well...that's a different story, especially on the track where I used to race (before I moved near Atlanta). There, having a one-way and a tire hit a 2X4 was a deadly combination for a front belt.
Being able to remove the rear diff easily, quickly, and "cleanly" is priceless to me, especially with ball diffs. I can remember countless times where my impulse diff would become "gritty", but I did not want to take the trouble to rebuild the entire car to get to the diff. If the diff is not smooth, neither am I .
I also remeber a day, a couple of years ago, when I stripped a front belt, replaced it, then stripped another one. I was so discouraged, having already rebuilt the front end in a hurry, I actually wanted to go home, and that rarely has happened to me, because I would usually rather be at the track than anywhere else.
Meanwhile, my 710 has not hit the track yet. I have much to do to get ready for the Snowbirds.
Arun is offline
Old 01-07-2004, 06:50 PM
  #2766
CraigH's Avatar
Smile
Sorry guys didnt mean to go off.Just get sick of people complaining about the little things. Everything has a work around, a little weakness for better handling in always a plus. Hopefully better handling means we stay away from the walls.
CraigH is offline
Old 01-07-2004, 08:30 PM
  #2767
Sow&Steady's Avatar
Who was the driver and where?
Sow&Steady is offline
Old 01-07-2004, 08:33 PM
  #2768
Sow&Steady's Avatar
D, good luck in Bangkok ... guess this forum will be a little quiet over the weekend!
I can't make it, my 710 is not ready.
When you come back focus on tellu us about the race rather than entertain those with big dong's that can break Hudy tools!
Old 01-07-2004, 11:38 PM
  #2769
crashed_1's Avatar
Default Serpent 710
here's a pic of my ride...
crashed_1 is offline
Old 01-07-2004, 11:55 PM
  #2770
Data's Avatar
Perhaps in more detail to your survey, we should count the number of useful replies versus useless ones...
make sure to count the replies about the shipping weight and date code. those are really useful.
Just for the sake of arguing, we should still take into account when the thread was started. Of course if a thread was started 2 or even 3 years ago, more people would have visited and more would have replied too.
i know, almost 60 pages of posts was logged even before the car was released. not that i have a problem with it, just that it is amazing to me so much could be talk about a car that nobody even had.
by the way, good luck at the race. which car will you be driving ? 710 or 705
Data is offline
Old 01-08-2004, 12:04 AM
  #2771
Data's Avatar
and try not to walk sideway when you walk pass the gates at the airport
Data is offline
Old 01-08-2004, 12:20 AM
  #2772
Racing4Evo's Avatar
Mel S. ( I don't know how to spell his last name) This was at Revelation Raceway( where the Sedan Nationals was held).
Old 01-08-2004, 12:24 AM
  #2773
jfc_tech's Avatar
Default Re: Serpent 710
is that 710 or not obviously not
Crashed, whats camera do u use? my fuji not that clear
jfc_tech is offline
Old 01-08-2004, 12:25 AM
  #2774
Wouldnt it be a good idea to drill an extra hole in the flyweights. so your flyweights are in balance.
RobbyDV is offline
Old 01-08-2004, 12:58 AM
  #2775
jfc_tech's Avatar
I noticed, if i not mistaken, its like the MTX3 clutch. But MTX3 got 4 pieces...i think so. its just no holes on the flywheels. Man, this is the coolest mod i ever seen.
Now i gonna hold the launching day for my 710. I need to change the 1st pinion and this mod things
jfc_tech is offline
