Serpent S811 Cobra, Brushless... >
Old 05-15-2011, 07:48 PM
  #106
Tess's Avatar
Trader Rating: 14 (100%+)
Thanks for the info. Mike
Tess is offline
Old 05-15-2011, 07:49 PM
  #107
jzemaxx's Avatar
Originally Posted by zixxer
what he said ..except i run the stock metal gear it makes more noise
Sounds more like a nitro.....lol
jzemaxx is offline
Old 05-15-2011, 07:51 PM
  #108
hogmansp's Avatar
Trader Rating: 47 (100%+)
Noisy or quite the car is simply great!
hogmansp is offline
Old 06-05-2011, 03:59 PM
  #109
ffpm46's Avatar
Trader Rating: 179 (99%+)
Default Gearing help
Hello, just ordered the RCM kit. I plan on running a 2200 KV motor, what pinion gear should I go width? Also are there any other plastic spur gears I can use? I know AE, Mugen and Losi make one. Are they direct fit?
ffpm46 is offline
Old 06-05-2011, 04:56 PM
  #110
hogmansp's Avatar
The losi spur is a direct fit. I really like my 1900 on 4s and I am running 18-44 right now so if your dead set on the 2200 I would start out with a 14-15 if your going to run the 44 losi spur. I think your going to like the car compaired the Mugen. I am going to try a 1700 with a 20 to see if it will relax the bottom end out.
hogmansp is offline
Old 06-05-2011, 05:52 PM
  #111
ffpm46's Avatar
I have to run the Speed Passion Silver Arrow V2.0 1/8th Scale Brushless ESC/Motor Combo (2200kV), because of cost.
I guess I will run the AE 46T spur, I was told between 14-15 pinion. Sound right?
ffpm46 is offline
Old 06-05-2011, 06:00 PM
  #112
hogmansp's Avatar
I would start off with the 14 and work from there. If your kit has the steel spur in it I would save the money on getting a delrin spur till you found a ratio combo you are happy with. I know a spur is 13 bucks but why waste the money if you end up wanting a different spur than a 46. Just my .02
hogmansp is offline
Old 06-18-2012, 06:29 PM
  #113
JC Gascot's Avatar
Questions?? witch pinion size for a tekin 1700 on a cobra be?
I try the 16 tooths included in the kit but was getting hot so I went up to 18 and it still getting hot any suggestion? Hot 180 with both pinions!
JC Gascot is offline
Old 09-16-2012, 04:24 PM
  #114
Trader Rating: 57 (100%+)
what body are you guys running? the one i bought (used) came with the nitro serpent body. let me know. thanks
Pete Taulbee is offline
Old 04-24-2016, 01:02 AM
  #115
blarks's Avatar
Trader Rating: 33 (100%+)
Sorry to dig up an old thread guys but I'm having trouble finding one of these conversion kits, its disappeared off the rc monster site, I've sent an email and waiting a response. Thought I would ask here if anyone knows where I could possibly get one or an alternative conversion setup?
blarks is offline
Old 08-26-2016, 10:02 PM
  #116
egalsim's Avatar
Trader Rating: 44 (100%+)
Serpent 811 BE 2.1 Rally
egalsim is offline
Old 08-28-2016, 09:52 AM
  #117
jurejurman's Avatar
jurejurman is offline
