Serpent S811 Cobra, Brushless...
#79
So what baseline setup are you guys starting out with, put the finishing touches on my nitro the other day with chad p's setup and figure I will tune from there. Didn't know if that would be a good starter as well for the ebuggy or not, I run on your standard 1/8th scale track with a groove, not super high grip all the time but not loose very often either. All my stuff is on the way
#80
this set up worked really good for me at the warehouse ...i came to this set up mostly from jz ......he was able to help me get it on the right track ....the only thing im really gonna change for high bite tracks which this was ...is the sway bar i the rear ......if your running out doors on a loose track jz might wanna chime in as he has run the loosest of the loose ...and he kick some major azz .....the pdf is editable so feel free to save and use it for your own ...i will post my tekin settings asap ...and i still havent been able to get any clear pics of the motor mount
didnt get it in there but im running losi green springs in the rear which was also jz suggestion and it worked like butter
#86
serpent 811 brushless
i just made my own kit, motor forword, and brakes intact. its just flys on the track, car balance it close to perfect
PIC here: itīs worts a look, just put http and a : and then // in front of the link
peecee.dk/upload/view/301630
peecee.dk/upload/view/301631
peecee.dk/upload/view/301632
#89
Does anybody know when the S811-E will come out?
