Need Help With Tires.....
tower
have you tried tower hobbies? or stormer hobbies just try www.towerhobbies.com, or www.stormerhobbies.com, or you can also try www.speedtechrc.com there ya go
p.s.
hey by the way those links are bad you need to type in the web adress
my track
well in san antonio texas it gets pretty hot so most of us use sorex 36R tires and we might even need to use sorex 40R tires!! sorex have the best feel to me but if you need a good cold weather tire you should try the cs22 by take off that is the bomb for colder weather but if you track temp. is over 110 degrees i would go with the 36R or 40R if it gets super hot
Sounds like rubber slicks.
Buena Suerte, Boricua!
^5
Tom G
^5
Tom G
hey juan
all the tires i menchend are rubber we usually never run foam modified any more haha on asphault that is
Juan, you do realize that Jaco only makes foam tires? They don't make rubber tires.
www.jacoracing.com
www.jacoracing.com
hey,
you could try cs tyre's, you can get 4 different temp tyres and you can buy pre glued versions as well, it's the tyre they are using at the worlds later this year
hope this helps you?
J-P
J-P
www.jacoracing.com
www.jacoracing.com
im pretty sure as well that JACO only make foam tyress. I am also in agreement with JP that the cs tyre is the best on road rubber you can by for 10th touring.
