Need Help With Tires..... >
Old 06-11-2004, 08:32 PM
Juan C Munoz's Avatar
Default Need Help With Tires.....
Hi. I'm trying to find the Jaco Slick Tires. Do you know where I can find them on the Internet. Please let me know. Thanks !
Juan C Munoz is offline
Old 06-11-2004, 08:35 PM
HuDy WiNnEr's Avatar
Default tower
have you tried tower hobbies? or stormer hobbies just try www.towerhobbies.com, or www.stormerhobbies.com, or you can also try www.speedtechrc.com there ya go
HuDy WiNnEr is offline
Old 06-11-2004, 08:36 PM
Default p.s.
hey by the way those links are bad you need to type in the web adress
Old 06-11-2004, 08:37 PM
What tires do you guys use for electrics ?
Old 06-11-2004, 08:43 PM
Default my track
well in san antonio texas it gets pretty hot so most of us use sorex 36R tires and we might even need to use sorex 40R tires!! sorex have the best feel to me but if you need a good cold weather tire you should try the cs22 by take off that is the bomb for colder weather but if you track temp. is over 110 degrees i would go with the 36R or 40R if it gets super hot
Old 06-11-2004, 08:48 PM
Are those foam or rubber ?
Old 06-11-2004, 08:50 PM
Tom G's Avatar
Sounds like rubber slicks.
Buena Suerte, Boricua!
^5
Tom G
Tom G is offline
Old 06-11-2004, 08:58 PM
Ok, Cool
Because here slicks are the best tires we can use on electrics. And I wanted to know which was the best brand of rubber slick tires.
Old 06-12-2004, 10:01 AM
Default hey juan
all the tires i menchend are rubber we usually never run foam modified any more haha on asphault that is
Old 06-12-2004, 10:46 AM
Juan, you do realize that Jaco only makes foam tires? They don't make rubber tires.
www.jacoracing.com
Hondaguy is offline
Old 06-12-2004, 11:41 AM
J-P
J-P's Avatar
hey,
you could try cs tyre's, you can get 4 different temp tyres and you can buy pre glued versions as well, it's the tyre they are using at the worlds later this year
hope this helps you?
J-P
J-P is offline
Old 06-12-2004, 02:10 PM
Korey Harbke's Avatar
I use sorex 32R or 36R rubber tires or the Take off Cs- 27's or 32's. They are all great tires and work just abotu anywhere when the temp is right. So far my favorite is the sorex 36R though.
-Sushi Boy
Korey Harbke is offline
Old 06-12-2004, 02:37 PM
www.jacoracing.com
Really ? Because one guy over here, has Jaco Slick Tires... At least he told me they were Jaco, he probably tricked me then...
Old 06-12-2004, 03:27 PM
im pretty sure as well that JACO only make foam tyress. I am also in agreement with JP that the cs tyre is the best on road rubber you can by for 10th touring.
Bony85 is offline
Old 06-12-2004, 07:17 PM
Where can I find them on the Internet ?
