Tuning motors with brushes
#47
Originally posted by mafiaracers
WOW, THATS A LOT OF POST!
#48
bill is there any place get a reamer on-line using Paypal?
#49
So far, all I have found is Tri-Angle Precision; however, their minimum is 10 each. Still looking for a supplier on the Internet. Please tell me if you find one. I usually use PayPal too.
Now understand that the RH spiral is more precise than straight.
#50
Wow! Finding the appropriate .125" 'long' hand reamer is not panning out for me so far...
Anyone have a clue?
Anyone have a clue?
#51
McMaster Carr on line
#52
you can get one from grainger you will have to set up an act but it will be worth it they have 1,000 snds of tools it is called a
flute reamer
it is long and looks like a drill bit
flute reamer
#53
Graingers Website?...
#54
nvm I got it
#55
guys, do have any idea where can i get in the internet some motor recomendations gearing chart?
ie:
TAMIYA Type RR (23T) - ?????
TAMIYA Mod 11T - ?????
KAWADA 23T - ?????
etc... etc... etc...
thanks.
ie:
KAWADA 23T - ?????
thanks.
#56
so will polishing allow be enought to see a difference.....or do u have to do the whole reaming thing.........also thins like reaming is it noticable that it will be picked up at an inspection?
#57
Originally posted by stankulas
[B]you can get one from grainger [B]
From the 'Grainger' website:
"Please be advised that Grainger is a wholesaler, not a consumer retailer."
#59
I am wondering what you guys hope to acheive by reaming the bushings? I understand the idea: make the hole slightly larger with a better finish...... BUT i doubt you will be able to make a straight cut without making the hole oversize or elongated. Really you need to have a drill press or a bridgeport mill to clamp the endbell, and indicate the hole on centerline before running the reamer through there. I definetly wouldn't run the reamer through the can to do the bushings.
A better bet would be to HONE the bushings. One advantage to honing is the cross hatch pattern that is left after honing helps retain oil lubrication, whereas a reamed hole will not be a lubricative. But honing oil STINKS!!!
#60
Originally posted by popsracer
I personally would NOT ream my Bushings. Once they are properly seated and broken in, polishing is all that's needed.
And Big Jim Greenemeyer agrees with you on this point; so, I am only going to polish them using a q-tip on a drill and polishing compound.
Many thanks for your insight.
