Tuning motors with brushes >
Old 03-29-2004, 04:48 PM
  #46
mafiaracers's Avatar
Trader Rating: 22 (100%+)
WOW, THATS A LOT OF POST!
mafiaracers is offline
Old 03-29-2004, 07:36 PM
  #47
Trader Rating: 16 (100%+)
It's just an informative article from the Internet. Aim to give this info to others that may be interested in this topic. I didn't know. Love this forum.
Still Bill is offline
Old 03-29-2004, 07:38 PM
  #48
bill is there any place get a reamer on-line using Paypal?
True R/C Racing is offline
Old 03-29-2004, 07:44 PM
  #49
Hi True,
So far, all I have found is Tri-Angle Precision; however, their minimum is 10 each. Still looking for a supplier on the Internet. Please tell me if you find one. I usually use PayPal too.
Now understand that the RH spiral is more precise than straight.
Old 03-29-2004, 10:02 PM
  #50
Wow! Finding the appropriate .125" 'long' hand reamer is not panning out for me so far...
Anyone have a clue?
Old 03-30-2004, 05:38 AM
  #51
McMaster Carr on line
David Root is offline
Old 03-30-2004, 07:08 AM
  #52
stankulas's Avatar
you can get one from grainger you will have to set up an act but it will be worth it they have 1,000 snds of tools it is called a
flute reamer
it is long and looks like a drill bit
stankulas is offline
Old 03-30-2004, 07:14 AM
  #53
Graingers Website?...
Old 03-30-2004, 07:16 AM
  #54
nvm I got it
Old 03-30-2004, 11:06 AM
  #55
Mr. Sean's Avatar
guys, do have any idea where can i get in the internet some motor recomendations gearing chart?
ie:
TAMIYA Type RR (23T) - ?????
TAMIYA Mod 11T - ?????
KAWADA 23T - ?????
etc... etc... etc...
thanks.
Mr. Sean is offline
Old 03-30-2004, 12:16 PM
  #56
so will polishing allow be enought to see a difference.....or do u have to do the whole reaming thing.........also thins like reaming is it noticable that it will be picked up at an inspection?
h22ah is offline
Old 03-30-2004, 12:20 PM
  #57
popsracer's Avatar
Originally posted by stankulas
[B]you can get one from grainger [B]
Things might have changed, but the last time I delt with 'Grainger', they did not sell to the general public.
From the 'Grainger' website:
"Please be advised that Grainger is a wholesaler, not a consumer retailer."
I personally would NOT ream my Bushings. Once they are properly seated and broken in, polishing is all that's needed.
popsracer is offline
Old 03-30-2004, 01:04 PM
  #58
If you get a long reamer, you can actually align the bushings which will increase preformance, then polishing the bushings will make a very noticible difference. I did this stuff at last years stock nats and it was cool.
Old 03-30-2004, 01:48 PM
  #59
PitCrew's Avatar
I am wondering what you guys hope to acheive by reaming the bushings? I understand the idea: make the hole slightly larger with a better finish...... BUT i doubt you will be able to make a straight cut without making the hole oversize or elongated. Really you need to have a drill press or a bridgeport mill to clamp the endbell, and indicate the hole on centerline before running the reamer through there. I definetly wouldn't run the reamer through the can to do the bushings.
A better bet would be to HONE the bushings. One advantage to honing is the cross hatch pattern that is left after honing helps retain oil lubrication, whereas a reamed hole will not be a lubricative. But honing oil STINKS!!!
PitCrew is offline
Old 03-30-2004, 09:24 PM
  #60
Pops,
And Big Jim Greenemeyer agrees with you on this point; so, I am only going to polish them using a q-tip on a drill and polishing compound.
Many thanks for your insight.
