Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 01-30-2013, 09:27 AM
  #4876
fullsyzz's Avatar
Trader Rating: 121 (100%+)
Originally Posted by jackcarter3
KYOFU666
Hahahah
Thanks Ahole!
Originally Posted by Rfury
LA253
Always check the exploded diagrams for all the various part numbers. Much easier to find them on that than the full parts list.
Thank you....I don't even see it on the exploded view...
fullsyzz is offline
Old 01-30-2013, 09:31 AM
  #4877
Now that you have the part number you should see it.
Rfury is online now
Old 01-30-2013, 09:37 AM
  #4878
fullsyzz's Avatar
Yup, see it on the parts list now...thank you. Still not seeing it pictured or listed anywhere else but we're good to go.
fullsyzz is offline
Old 01-30-2013, 05:11 PM
  #4879
gelshocker's Avatar
Originally Posted by jwood7
Either arm can be used with either the wide or narrow holders. These r just different tuning options. The 521 arm has 2 holes and the 521-01 has one hole. The first page has a good explanation of the difference between the narrow and wide holders
Thanks, and also thanks to Capt. for the explanations on the first page. Just curious as all the setup sheets I see are matched that way (narrow with 521, wide with 521-01) and wondering if there's something you guys know that I don't! Cheers,
gelshocker is offline
Old 01-30-2013, 06:46 PM
  #4880
dfurutani's Avatar
521-01 arms come with the SP2. That was the first car with the wide hangers. 521 arms came on the SP, which had narrow hangers. UM566 rears from the WC car are the same as 521 rears. (As are LA272 rears)
dfurutani is offline
Old 01-31-2013, 07:42 AM
  #4881
Originally Posted by seth556
I just reamed out the part that captures the pin a tad and the regular pin fits, just use a 2mm shim on either side and it works perfect.
I was just about to write the same thing. Works perfect
shark2288 is offline
Old 01-31-2013, 11:46 AM
  #4882
jackcarter3's Avatar
I don't have my manual nearby. Anyone know what size e clips fit the shock shafts? 2.5 or 3mm?
jackcarter3 is offline
Old 01-31-2013, 12:03 PM
  #4883
fullsyzz's Avatar
Check your text msgs. holmes. 1-e025 2.5mm
fullsyzz is offline
Old 01-31-2013, 12:08 PM
  #4884
I did. Thought you were ignoring me.
Old 01-31-2013, 04:52 PM
  #4885
steam's Avatar
Just to confirm
The the 521 and the 521-01 arms are exactly the same except for the 521 have 2 holes for the shock mounting and the 521-01 have a single hole that is between where the 2 holes would be.
other then that there exactly the same correct?
steam is offline
Old 01-31-2013, 05:29 PM
  #4886
Originally Posted by steam
Just to confirm
Yeap. Exactly.
Rfury is online now
Old 02-01-2013, 12:27 PM
  #4887
pli
Aluminium bulkhead for RB6 by GHEA.
pli is offline
Old 02-01-2013, 01:47 PM
  #4888
aloksatoor's Avatar
Trader Rating: 43 (100%+)
where did u buy urs?
aloksatoor is offline
Old 02-01-2013, 01:49 PM
  #4889
Cpt.America's Avatar
Trader Rating: 52 (100%+)
How are they different than ones already produced? How much does it weigh compared to the stock piece?
I'v never had an issue with the factory front hanger on either the rb5 or rb6.
Cpt.America is offline
Old 02-01-2013, 02:39 PM
  #4890
t8rtot's Avatar
Trader Rating: 14 (94%+)
Looks quality but I think it would lead to more bent or broken parts
t8rtot is offline
