Tires
Tires
Anyone knows some good tires for a carpet track, and wich inserts i should use???
i dont know if you have to use rubber in holland but if you can i would use foam tires for a carpet track.
pit shimizu 20 or 25 with firm inserts. but it really depends on what the fast guys on your track use.
do i have to use hard or soft inserts??
Try Sorex 24 rear and 28s in the front. I use the Sorex B insert for stock. Also Pit 24R in the rear and Pit 27R in the front will work good. I think the Pit 25s are no longer made. The new compunds are 20R,24R,27R,30R, in these I use Pit medium inserts. Try Speedtechrc.com. They have tire/insert/wheels combos for real cheap.
Xpress team tires, with stock inserts, are an excellent starting point for a carpet track. They have tons of traction and wear fairly good. You can also use HPI Black Pro Molded Soft Inserts in them for more even tire wear.
