Old 03-17-2002, 03:25 AM   #1
Send a message via ICQ to Speedmind
Default Tires
Anyone knows some good tires for a carpet track, and wich inserts i should use???
Speedmind is offline   Reply With Quote
Old 03-17-2002, 04:24 AM   #2
ausracer's Avatar
i dont know if you have to use rubber in holland but if you can i would use foam tires for a carpet track.
ausracer is offline   Reply With Quote
Old 03-17-2002, 04:47 AM   #3
Trader Rating: 69 (100%+)
pit shimizu 20 or 25 with firm inserts. but it really depends on what the fast guys on your track use.
marvi is offline   Reply With Quote
Old 03-17-2002, 04:55 AM   #4
do i have to use hard or soft inserts??
Old 03-17-2002, 06:55 AM   #5
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Try Sorex 24 rear and 28s in the front. I use the Sorex B insert for stock. Also Pit 24R in the rear and Pit 27R in the front will work good. I think the Pit 25s are no longer made. The new compunds are 20R,24R,27R,30R, in these I use Pit medium inserts. Try Speedtechrc.com. They have tire/insert/wheels combos for real cheap.
Core Creations is offline   Reply With Quote
Old 03-17-2002, 09:26 AM   #6
CRASH's Avatar
Trader Rating: 26 (100%+)
Xpress team tires, with stock inserts, are an excellent starting point for a carpet track. They have tons of traction and wear fairly good. You can also use HPI Black Pro Molded Soft Inserts in them for more even tire wear.
CRASH is offline   Reply With Quote
Old 03-17-2002, 10:22 AM   #7
Regional Moderator
Darkseid's Avatar
For high quality non-fuzzy carpet, slicks like the Sorex28r are much better than the Xpress tires.
TLR 22...Tamiya F104...
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 10:38 AM
Team Orion tires / monster truck tires and weld wheels evostyle R/C Items: For Sale/Trade 4 04-25-2006 09:52 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 10:27 AM
