Ko Propo
Ko Propo
Are there any aftermarket recievers that will work with Ko Propor? Or is there anywhere to get the recievers for cheap?
thanks
thanks
Regional Moderator
if you are running a 27mhz.
you can go with the lrp phaser or novak xxl
if 75mhz. you can run a novak xxl
pro3racing
team ko propo
pro3racing
team ko propo
so I assume the LRP phaser will not work with a 75 mhz KO PROPO?
I have a KO vantage II radio & use receivers by KO, Hi-tech, Futaba and Jeti. They all work fine as long as you use KO xtals in the transmitter and receiver.
Hello
I use a KO ex-11 with an LRP Phaser 40mhz with Ko crystals!!!
I was able to use futaba crystals on it, because of a conflict.
It worked just fine, but I know it should only be with Ko crystals.
I fine the same. I have the Limited Mars and can run any receiver on 27 as long as I use KO crystals....
KO is GREAT PRODUCT!
any one know when the helios is coming out and how much it costs?
was ist los? any one know when the helios is coming out and how much it costs? You mention helios is this there new radio that is taking over the ex1?
Have you got info on this system? if so can you please tell me where you found it
Thanks Ryan
Thanks Ryan
wow that looks crazy as that radio it look like it would be hard as to use i think the older one looked easyer to use. wonder what type of price it will be and if its got any other features??
Ryan
Ryan
Originally posted by Disaster999
yupyup..its a new radio from KO...it looks really cool!
What's the key differences between Stick and Gun controls?
Hi all!
While the topic's on the transmitters, I'd like to ask apart from the different layout, what is the advantage of Stick VS Gun transmitters?
Only thing I can make out is the gun type's movment range is 2/3 Forward, and 1/3 brake. And the stick type is probably 1/2 Forward, 1/2 brake.
This means the brakes have more resolution. Or does the ESC simply map the 2/3 brakes over to the 1/2 movement range anyway?
Thanks!
~Alvin
Thanks!
~Alvin
Can some well pleze tell me is this the model that will be taking over the ex1 or the ex11 model?
There just doesnt apear to be the same amount of setup options on the one in the picture as they have on the ex1 moore like the fewer buttons on ex11.
Man will have to consider getting one now as the old stock is not being sent to reatailers at present.
Ryan
Ryan
