Old 05-01-2002, 07:13 PM   #1
Default Ko Propo
Are there any aftermarket recievers that will work with Ko Propor? Or is there anywhere to get the recievers for cheap?
thanks
Boss78 is offline   Reply With Quote
Old 05-01-2002, 07:43 PM   #2
Regional Moderator
R/C Tech Charter Subscriber
if you are running a 27mhz.
you can go with the lrp phaser or novak xxl
if 75mhz. you can run a novak xxl
pro3racing
team ko propo
Ko Racer is offline   Reply With Quote
Old 05-01-2002, 11:31 PM   #3
vthondaboi's Avatar
Send a message via AIM to vthondaboi Send a message via Yahoo to vthondaboi
so I assume the LRP phaser will not work with a 75 mhz KO PROPO?
Kyosho ST-RR
Kyosho SP2
E-Flite Blade CX2 Heli
vthondaboi is offline   Reply With Quote
Old 05-02-2002, 01:32 AM   #4
Trips's Avatar
Trader Rating: 16 (100%+)
LRP Phaser receivers are not available on 75mhz.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 05-02-2002, 02:31 AM   #5
JohnA's Avatar
I have a KO vantage II radio & use receivers by KO, Hi-tech, Futaba and Jeti. They all work fine as long as you use KO xtals in the transmitter and receiver.
JohnA is offline   Reply With Quote
Old 05-03-2002, 11:35 AM   #6
lem2's Avatar
Default Hello
I use a KO ex-11 with an LRP Phaser 40mhz with Ko crystals!!!
I was able to use futaba crystals on it, because of a conflict.
It worked just fine, but I know it should only be with Ko crystals.
lem2 is offline   Reply With Quote
Old 05-03-2002, 01:43 PM   #7
RBLove's Avatar
Trader Rating: 72 (100%+)
I fine the same. I have the Limited Mars and can run any receiver on 27 as long as I use KO crystals....
KO is GREAT PRODUCT!
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 05-03-2002, 11:48 PM   #8
any one know when the helios is coming out and how much it costs?
was ist los? is offline   Reply With Quote
Old 05-04-2002, 03:40 AM   #9
Ryan C's Avatar
was ist los? any one know when the helios is coming out and how much it costs? You mention helios is this there new radio that is taking over the ex1?
Have you got info on this system? if so can you please tell me where you found it
Thanks Ryan
Ryan C is offline   Reply With Quote
Old 05-04-2002, 04:04 AM   #10
Regional Moderator
disaster999's Avatar
yupyup..its a new radio from KO...it looks really cool!
disaster999 is offline   Reply With Quote
Old 05-04-2002, 04:08 AM   #11
Regional Moderator
and the short explaination
Old 05-04-2002, 04:56 AM   #12
Ryan C's Avatar
wow that looks crazy as that radio it look like it would be hard as to use i think the older one looked easyer to use. wonder what type of price it will be and if its got any other features??
Ryan
Old 05-04-2002, 11:15 AM   #13
dtm
dtm's Avatar
Send a message via ICQ to dtm
Sure looks BUTT ugly.......if this is KO's idea of their top of the range radio.....I will have to reconsider if I'm going to continue buying their servos!!!!!!!! Can't be seen to be spending money on such a bad taste company so that they can continue to produce such tasteless products!!!!!!!
dtm is offline   Reply With Quote
Old 05-04-2002, 11:25 AM   #14
Alvin's Avatar
Default What's the key differences between Stick and Gun controls?
Hi all!
While the topic's on the transmitters, I'd like to ask apart from the different layout, what is the advantage of Stick VS Gun transmitters?
Only thing I can make out is the gun type's movment range is 2/3 Forward, and 1/3 brake. And the stick type is probably 1/2 Forward, 1/2 brake.
This means the brakes have more resolution. Or does the ESC simply map the 2/3 brakes over to the 1/2 movement range anyway?
Thanks!
~Alvin
Alvin is offline   Reply With Quote
Old 05-04-2002, 02:29 PM   #15
Ryan C's Avatar
Can some well pleze tell me is this the model that will be taking over the ex1 or the ex11 model?
There just doesnt apear to be the same amount of setup options on the one in the picture as they have on the ex1 moore like the fewer buttons on ex11.
Man will have to consider getting one now as the old stock is not being sent to reatailers at present.
Ryan
KO PROPO BMC-VFS esc Molala3 Electric On-Road 0 04-23-2008 11:57 AM
KO PROPO VS-1 FS/FT Headshot R/C Items: For Sale/Trade 5 11-11-2007 06:16 PM
ko propo buffalobill989 R/C Items: Wanted to Buy 2 08-09-2006 05:08 AM
~F/S Ko Propo Mars R/Ko Propo VFS 2000 Pro/BMI FK05~ RandomTask R/C Items: For Sale/Trade 5 06-21-2006 10:18 PM
WTB Ko Propo VFS-1 Pro Roberto Falcon R/C Items: Wanted to Buy 5 10-22-2005 11:36 AM
