Removing Polycarb paint
Old 01-09-2015, 10:40 AM
Default Removing Polycarb paint
Question: how do you remove poly paint when painting inside of RC car body? I tried lacquer thinner but it scratches the body. Will anything else work? Thanks-
bowl806 is offline
Old 01-10-2015, 04:15 AM
I tried acetone, took the paint off nicely but ruined the body. I thought it was going well but then noticed the bod was getting really brittle.
Dentdog is offline
Old 01-10-2015, 04:44 AM
mhughesjr's Avatar
Believe it or not, but brake fluid works. It is a slow and messy process, but does the job. Just take your time, let it sit for awhile after you have agitated it. Wipe it off and repeat until you get the results you like.
mhughesjr is offline
Old 01-10-2015, 03:44 PM
Thanks! Might save me from buying a new body?
bowl806 is offline
Old 01-10-2015, 05:08 PM
Trader Rating: 15 (100%+)
Try gasoline or nitro fuel
aft53 is offline
Old 01-11-2015, 07:02 AM
I nhave used Dot 4 brake fluid; as mentioned above it is a slow process but it will work
larc is offline
Old 01-11-2015, 02:16 PM
Trader Rating: 61 (100%+)
Originally Posted by Jdunfee424
brake fluid works but it is a very slow time consuming process.
After 2 hrs of soaking and wiping. I gave up and just bought a new body.
mr240 is offline
Old 01-12-2015, 09:32 AM
That response got a giggle and a snort from me so I think that's the way to go- LOL! I got tons of $$$ to throw away (NOT!)
bowl806 is offline
Old 01-16-2015, 05:14 AM
DWT74's Avatar
NON-ACETONE nail polish remover, works great and fast! Wont ruin your body either. Walmart brand works great, wont turn or soften your body or make brittle.
DWT74 is offline
Old 01-16-2015, 06:45 AM
Trader Rating: 76 (100%+)
None of this actually works* 100%. Just get a new body. If you can't afford one, then you are in the wrong hobby.
Not trying to be a ass, just some truth there.
Metalsoft is offline
Old 01-17-2015, 08:04 AM
Rugspin's Avatar
Denatured Alcohol works. I also use it to prep the bodies. Take a bit of scrubbing but it will come off clean without damaging the body
Rugspin is offline
Old 01-18-2015, 03:37 PM
Your always better off buying a new body than trying to use a old body
leothegreat is offline
Old 01-20-2015, 09:42 AM
Jim85IROC's Avatar
Sometimes that's not an option. For those of us who are into vintage RC, sometimes a new body is a ton of money, if you can find one at all.
Jim85IROC is offline
Old 01-23-2015, 06:06 PM
I've had great success with using nitro fuel.
CrankyMuppet is offline
Old 01-24-2015, 05:25 AM
i guess for me,i'm fairly new to the hobby and by the time im thinking paint it because i have a new body. I wish i could reuse my body's lol but im too hard on them and they come off in pieces :rock:
TrespasseR_MN is offline
