TQ Wire
#16
I have added a 85mm flatwire sensor cable to the line:
The "Fairtrace" was designed for TC's using an LRP speedo with the sensor port positioned to the center of the car. In this instance the 70mm was too short and the 100mm too long.
http://www.tqwire.com/sensor.htm
#18
When using the #2204 Hyperion balance extension with the new HP-EOS0720i SUPER DUO3 charger you need to align the cable's plug with the right side of the charger port.
#19
Hi, Im looking for white 16G and 13G wire and am not having any luck finding any. Do you carry that by chance? I didnt see it on your web site.
#21
I'm checking with my mfg to see of they have anything in stock. Although I have received a few inquiries for white, not enough to make a (large) investment. I'll see what I can do for you.
#22
THANK YOU for all time and work you put in on setups for the TOP cars so we can just "steal" them from you!
Be careful what you wish for........I'll be stinkin up Horsham soon.
#23
Going to make the Classic, Ralph?
-Sean
-Sean
#24
#25
The #2204 balance extension made for the Hyperion charger will also fit the Hitec X4 charger. Align the cable end to the right side of the port.
Thank you Rick Simons for pointing this out!
#28
A big thanks to TQ Wire for the support of the Midwest Grandslam. Not only do they make some awesome products to make your ride fast, Ralph is a tough competitor and a lot of fun to pit around and race against.
Remember, if you experience a stiff wire or sensor problem lasting longer than four laps consult TQ racing wire.
#29
Always a great race pitting with Ralph. Great wire products in addition to pinion trade in program and such advice as, "You aren't going to rebuild that shock?"
Thanks Ralph!
Thanks Ralph!
#30
Trader Rating: 20 (100%+)
Ralph, thanks for the awesome products that you constantly supply to racers!! The sensor wires and battery wires are so DIALED!
BTW thanks for the words of encouragement after the races!! Always nice to hear from ya!!
See ya at the races soon!!
