CEFX Griffin 12 & Griffin 10 WGT
#91
Hi Gents,
I did a setup sheet some time ago for this car, a little trick to get something nice.
Josh'setup is on one of this sheet.
HTH
HTH
#92
For club racing tracks where the grip was lower I found I had to run a lighter front king pin lube (around 10K) with a little more sag in the front springs. That especially helped with the tight slow speed sections. Also running gold springs on the rear of my car. Blues are easy to drive but the golds just rip the corners. The golds however are very sensitive to how much pre-load you are running on them.
#93
Going for first club race with my Griffin 12 this weekend.
Can folks chime in with recommended rollouts or rollouts they've run for 17.5 on a small technical track with medium traction? I'm currently running 79mm (likely on the high side) from last year which was when I ran a duo 2 13.5. Ran 43/73 with 43mm Rear. I'm running a Duo 1 17.5 btw.
thanks in advance
thanks in advance
#94
On a postage stamp size track and lots of tight 180s (50'x30') I was running 78-79mm with 17.5 Duo and Duo 2 motors. At a larger track I think around 80'x40' I was running in the 81-82 mm range.
This was with Tekin Vegas 208 software, I haven't tried the newest version in 1/12th yet this season.
#95
#96
The order is going in this evening for the new CEFX 2010-2011 indoor season t-shirts, sweat shirts and hoodies. If anyone is interested in these please let me know so we can make sure to make enough of the different sizes. Just shoot me an e-mail at [email protected] with the size/style/quantity you are interested in. They are being printed next week so we should have them pretty quick!!
New chassis, brass weights and new steering anouncements coming soon!! Yes, I have been flooded with oval car orders but we are finally getting caught up with those and we are back working on new items for the Evolution.
As well as the Evo, we are starting to look more heavily into our own plastics and molds to get the Griffin kits more complete. Not sure exactly where we will start but the front end, shocks, links and center pivot are all on the list of to-do here very shortly!!
#98
Josh, which body you like the best now for the car, on a tight track?
#99
ran the car for the first time in anger this weekend and have to say I was impressed. Need to work on smoothing it out a bit as it's slightly too aggressive at the moment, but that's down to setup and me more than anything else.
#101
So guys any pics , reviews of your Griffin's? Been quiet up here on this thread. Looking to jump back in to 1/12th scale after a Hiatus, really liked Josh's cars still have my original green c-12, Like to see more about the Griffin.
#102
A question about my Griffin 12. I've had two instances where the car has taken a hard impact to the left rear (due to hitting the inside of click-trak at the end of a straight going into a right turn). I've had to add a ton of shims to set the Track width from the center point on the pod. The impact seems to just blow the shims right into the bearing, causing the subsequent destruction of the bearing.
Anyone else seen this issue ? Issues with my build ? Never had this issue when I ran a 12R5 last season although the track layout was different.
thanks in advance
thanks in advance
#103
Hello There,
I just picked up a used CEFX Griffin 1/12th. Can you tell me how many .020" gold Rear axle shim's can i use to make 1.72mm rear width?
#104
Hey noline, been hoping to find a used one where did you come up with one?
I would just center the axel off the pod and that will give you the proper shims
#105
No pics, setups from Cleveland? Tuning info? Josh wins Mod and nothing comes out reallly about it? Whays News Josh? Anyone have results, reviews from there Griffin's being run? Am looking for one also if someone has one to sell!!!
Come on guys keep this thread going!
