Schumacher Corner
Originally Posted by yyhayyim
When is the next big race team Schumacher is preparing for?
The next one after that is the eXpress race at Jackson, NJ 8-10 June.
Someone posted some vid from Reedy on the main Reedy race thread...
Anyone doubting that the Mi3 was dialed should check that vid out. Weylin's car looked awesome he just had some bad luck. Scotty even comments at one point during the vid that Weylin was the fastest car on the track.
Good job to all the Schu peeps who raced at Reedy.
Originally Posted by Randy Caster
Just found a couple cool pics of my car from the RROC taken by Jason Boulanger..
How far back should I put my wing for low-med traction out door asphalt? At the 2006 worlds, it seems lots of drivers had them as far back as possible...at the Reedy 2007 race, Reinard and others also ran it far back...I'd love find out how Weylin, Randy, PW and Alex ran theirs and who that effects their set up...thx
Originally Posted by Jon Kerr
Here's the order I do all of this.
1. Set your ride height.
2. Set your droop above ride height.
3. Take tires off and use droop blocks to make sure your droop is even. (This isn't to actually set your droop, only to make sure both sides are even. Use this time to make sure the chassis is flat on the droop blocks and not rocking back and forth.)
4. Put on setup station to check camber and toe.
5. Take off setup station and put on tires.
6. Check tweak on a tweak station or by lifting one end at a time. Don't adjust by droop screws. You've already made sure the droop is equal on both sides. Use your shock collars. If you have to have too much of a difference in your preload, double check your droop settings and that the chassis is flat.
Originally Posted by POUNDITRACING
Hay, Nice pics of the body. Hope it worked out for you. Give me a call.
Camber should always come before droop to make sure the tires are all at the same angle when lifting the car up if that's your method of droop.
BTW- I still think you could have done a 12.4 with headlights.
I guess Dale from Protoform agrees with you guys too. RCCA wanted to shoot some photos of my body but A-Lo had to donate some headlight stickers before Dale would let them shoot the body lol. I am guessing 12.8 if I would have run them during the race though.
Did you mail my phone back yet Randy?
Trader Rating: 51 (100%+)
Did anyone try the DNA asphalt at the Reedy race? I really like mine on my MI2 EC and now on my MI3. It has really good steering and overall traction.
Good Day
Do you guys put lube in your front cvd's ? (if so which one?), i find if i run them try i have small iron fillings on the inside bearings where the axle rubs the cvd cup.
Also i used to use Tribo Power Matrix as a bearing and bushing lube, and found it the best to use for this purpose, i can no longer get a hold of it, what alternatives could i use, Something that is found in everyday hardware stores and is just as good, either reel oil, gun oil, valve oil ? for bearings and bushings?
Thanks alot guys.
Thanks alot guys.
I usually make sure the camber is very close with a camber gauge first before I do the droop but that can be off with the slight bend that seems to be in most pre mount tires. I use the setup station to make sure they're dead on.
You can call it Pound It Racing. Bodies, motors, and really bad setups. I'm working on that.
