Tub Cyclone `S`
#931
Hey guys I'm new here. I just got my cyclone S setup and I reversed it into a curb medium speed and I broke the battery clip post.... I supper glued it but wondered if other people have had the problem. Also I was wondering whether replacing the belt pulleys and putting aluminum ones is worth it?
#932
nope to both;Get a 3racing graphite chassis first@ around 35bucks--you will be happier.I did
#933
#934
Does anybody has the link to the manual of Cyclone S Drift Special Edition?
If not, does it come with universal shafts front/rear?
Thanks.
Thanks.
#935
spacer
For those of you running the s have you tried running the larger 2mm spacer in front of the rear axel to make for a longer wheelbase?Right now i have the smaller 5mm one in the front and was wondering if i swapped them it would give me more rear end grip and not loop out as much when harder on the throttle around corners.
put the 2 mm shim at the back and .5mm front (short wheel base) and make sure you do the same at your knuckles...yeh more rear bite...as for me i just let the front end stock(long wheel base)...hope this helps...just try it if it does'nt work for you just put it back the same way and do some other changes...
#936
Hello, Im just wondering were does everyone get there 3racing parts I'm looking for the main chassis and upper deck specifically.
#937
#938
I would also get the aluminum c-hubs the front knuckles and the rear uprights . 3racing products are quite good I've never had a problem. Good luck:
#939
I have just put together a cyclone s and I just put on the tc schocks on. However I am still looking for aluminum shock collars for them. I cant seem to find the Pro 4 ones anywhere can someone tell me whose aluminum shock collars will fit on this car and who has them in stock.
#941
#942
max spur size (trying to get motor to fit)
Hi there. Whats the max (48pitch) spur I can fit??
Im having issues with fitting a brushless motor.
#943
I'm new to electric actually at this pomt I don't even own anything electric but I'm wanting to get into carpet racing. I've been looking at the cyclone rtr since I'm not really sure carpet is what I want to do. I'm just wanting to race in a 17.5/27t class. Is the cyclone rtr as upgradable as hot bodies makes it out to be? Can the chassis be upgraded say to the tc chassis on down the line? For a beginner is it even a fairly competitive car to start out with? Any help or input would be great!
#944
#945
It's a very good competitive car. You can go to Hot Bodies web site and see the various hop ups that they offer. 3Racing makes hop ups for it. I know you can get graphite shock towers, cvd's, a one way, a solid axle, but I don't know if you can get a graphite chassis for it. You can email Hot Bodies and ask them.
