Best Lubricant for Bearings?
#91
I'm liking my RIG 2 (for now) =
http://sport.birchwoodcasey.com/RIG/...9-8195cb71808f
Additionally, it's gotta be good if it's banned in California!
#93
Whats funny about all these different products contain similar chemicals.
You can use you favorite oil and thin it with octane booster to
your desired thickness.
You will be very surprised on the results.
#94
Molykote G-2001, High Speed Grease
#95
Well, I'm about to divulge a speed secret from the past 12 years. Not too worried though cause, good luck finding it!
Light weight oils will sling from a bearing, leaving parts of it dry after a short time.
Not with this stuff. It leaves a thin dry film of molybdenum disulfide, making a well lubricated, very fast and free bearing.
#96
It would appear that LubeCon is now part of the Castrol Oil Syndicate.
http://www.lubecon.com/
But there's plenty of other sources for molybdenum disulfide (oil) lubricants around.
http://www.schaefferoil.com/dry-lubricant.html
http://www.belray.com/bel-ray-assembly-lube
Etcetera.
Would these not be the same, similar as what you have?
Etcetera.
#97
Etcetera.
Etcetera.
From what I can tell, the castrol lubecon 301 is what the stuff we've been using is called now.
http://ableaero.com/CasTDS/Cas301.pdf
I'm sure the other company's have similar products.
#98
A little tangent to this thread:
What would be the best lube for ceramic motor bearings ?
The mentioned above or anything else ?
#99
Have used Molly based lubes like this for over 20 years, but still find my RC bearings work best (least rolling resistance) with some thinned Mobil 1 motor oil. I use the dry film on areas like suspension arm pivots and steering blocks or even CVD joints but not in my bearings.
#100
Actually it is quite easy to get, same stuff as Dry Slide and Bike Aid which you can get at any bike store or even Amazon. http://www.amazon.com/Bike-Dri-Slide.../dp/B001F2Y25G
#101
I find the bearings with Molly spin super east when you first apply it (let it wick into the shield) but come back a day later and try the same bearing it spins smoothly but nowhere near as long as it did the day before (when the lube was wet) or with a thin liquid lube.
Molly based (dry film) lubes are great for high pressure low speed use like machinery ways etc but usually for high speed use it is often used as an additive to other base lubes like grease for things like axle bearings. There are reasons dry film lubes are not used in industrial gearboxes vs wet liquid lubes. But if you are happy with it in your bearings then that's all that really masters.
#103
#104
Yes, I thin the Mobil 1 oil with octane booster works well.
