Old 10-28-2005, 09:13 PM   #1
WD40's Avatar
Default Best Lubricant for Bearings?
I have metal sealed bearings in my touring car. I soaked them in motor spray over night to get all the extra grease out. I was just wondering what some experts recommend for lubrication for the bearings? I would like something that can get in the seals without taking them off if possible. I want my drivetrain to roll as smooth as possible. Any help would be appreciated.
WD40 is offline   Reply With Quote
Old 10-28-2005, 09:15 PM   #2
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I am no expert but my bearings run very smooth...
Acer makes a very thin oil that lets your bearings run free....
Others include
Nexus racing lube is very good as well.
Trinity Royal oil is nice but all three need to be reapplied more often..
Hope that helps,
-SHookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-28-2005, 09:52 PM   #3
WD40's Avatar
I have an opinion on this that differs from many people. I think that maybe a little thicker lubricant is better than the thin oils that people are putting on bearings today. A very thin oil applied to the bearing will spin out after the first run. A thicker oil will stay inside the bearing for longer. Now I know some of you are saying, the thicker the oil the more friction, which is true.....but some oil in your bearings after the first run is better than no oil. Also the thicker oil thins and viscosity decreases as the bearings heat up. Just my two cents worth to my own question. If anyone disagrees or knows a very good lubricant for the bearings please let me know.
Old 10-28-2005, 09:57 PM   #4
Davidka's Avatar
Trader Rating: 77 (100%+)
I would give Pro Gold (also known as Pro-Link) bicycle chain oil a try. It is as thin as water but has amazing film strength. I use it on my bikes and my chain stays quiet for 200+ miles. Works great in bearings and doesn't attract nearly as much dust as normal oils.
Old 10-28-2005, 10:10 PM   #5
Sushi Man's Avatar
Send a message via AIM to Sushi Man
i just use skateboard bearing lube. It works great.
Sushi Man is offline   Reply With Quote
Old 10-28-2005, 10:25 PM   #6
koabich's Avatar
Send a message via Yahoo to koabich
I recommend the Acer SIN oil. Never had a problem with the bearing becoming dry. As a matter of fact, I ran the exact same set of my bearings in my TC3 for 3 years and never had to replace one of them. All I did was clean the bearing out once a month and then relube with the Sin Oil.
koabich is offline   Reply With Quote
Old 10-28-2005, 10:29 PM   #7
Ghostfit's Avatar
I lube mine with Synco PTFE dry-flim lubricant.
...Heck, I use this stuff on literary everything on the car, Susp links, Drive cups, Spur/pinion gears ....anything that moves (including my fingers !)
Ghostfit is offline   Reply With Quote
Old 10-28-2005, 10:48 PM   #8
WORD
Old 10-28-2005, 10:49 PM   #9
Trader Rating: 29 (100%+)
mobil 1 is really hard to beat and you will definatly never run out once you buy a quart lol
Mdoc is offline   Reply With Quote
Old 10-29-2005, 12:04 AM   #10
PitCrew's Avatar
Teflon impregnated oil also works very nice. It can be purchased at Radio Shack, among other places. It is fairly thin, so works into the bearings well, and forms a coating of Teflon, which has about the lowest co-efficient of drag of just about anything. With that kind of lubricity, there shouldn't be any heat build up, so viscosity is not really an issue as it relates to heat...
PitCrew is offline   Reply With Quote
Old 10-29-2005, 12:39 AM   #11
Soviet's Avatar
5W-30 Motor Oil.
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 10-29-2005, 06:25 AM   #12
mistercrash's Avatar
5W30 Mobil 1 synthetic motor oil
No brain, no headaches.
mistercrash is offline   Reply With Quote
Old 10-29-2005, 06:45 AM   #13
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
0W-30 Mobil 1
A Quart will last about 97 years per my calulation
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 10-29-2005, 07:36 AM   #14
diesel's Avatar
Hi there, here's a page from avidrc on bearings that i found quite informative.
http://www.avidrc.com/?action=support
Cheers.
diesel is offline   Reply With Quote
Old 10-29-2005, 08:35 AM   #15
BatJam1's Avatar
heres what i use on alot of aplications!It protects against friction,Reduces heat,treats the metal.
BatJam1 is offline   Reply With Quote
Tungsten Disulfide engine pre breakin Lubricant Relay8039 Onroad Nitro Engine Zone 14 12-28-2010 09:50 AM
PowerKote lubricant for off-road? captain america Electric Off-Road 1 11-29-2010 03:58 AM
WTB: TRIBO R/C Power Matrix Commutator Lubricant Buggy Master R/C Items: Wanted to Buy 8 07-23-2007 08:54 PM
lubricant spray any parts? zax Electric On-Road 0 09-12-2005 02:05 AM
Bearing Lubricant rcfaster Electric On-Road 13 05-12-2005 06:19 PM
