Kyosho v-one rrr
#5236
Heavier weight oil in the diff will take away steering going into a corner (off power) and add steering coming out (on power).
#5237
Originally Posted by robert maestrey
You might want to also go to a heavier weight oil in diff if you have understeer...this will help both on and off power understeer...
I apologize my mistake you guys are correct........not both only helps on power....not of power......dont know what I was thinking.....I am a little sick with the flu.....
#5238
#5239
Originally Posted by markp27
You have my sympathy, Robert - I'm trying to recover from Chicken Pox at the moment - almost killed me - the older you are the worse it gets
#5240
Feel somewhat better, just no energy and sleep the whole time. But you're right about where you get the spots really horrible. My doc says it'll take another couple of weeks before I'm back to normal.
The good thing about this is that the nitro seaons starts in a couple of weeks here, so as soon as I'm well again, I can start driving Nitro again
#5241
hope you feel better......I heard when your older its real bad......like you get it in your throat and stuuf like....
Cheers
#5242
Originally Posted by ziggy12345
It can make you impotent!
Cheers
Cheers
#5243
LOL don't scare Mark
#5244
Sorry Mark but its a fact!
#5245
Man that's nearly as bad as traction rolling
#5246
#5247
what part of florida are you from George......also where were you pitting at the race and with whom......
Still getting adjusted to Quiteness & the noisiy crickets it took me a while to fall asleep since im so used to all the noise in NY.
#5248
what's up guys! I'm wondeing if you guys come across a problem on the clutch bell bearings? keeps on breaking down? only the 5x8 and 5x10 is find, for about 2 to 3 run time for 5min fur run.
ps: need HELP to fixs this problem.
thank you
cooldude.
thank you
cooldude.
#5249
thank you
cooldude.
thank you
cooldude.
#5250
thank you
cooldude.
thank you
cooldude.
