VTA tuning Q&A
#346
as far as my setup goes...its stock TC3...I ran blue front springs and silver rear....30wt all around....10mm all around...about 3mm droop....I ran rear shock towers all around....on the front shock tower...outside hole..on the arm..inside hole....on the rear shock tower....inside hole....on the arm...outside hole...double foam bumpers up front...lol..and I ran some washers on my front wheel hubs to make the front wheels sit out some for looks...(HPI mustang body)..I dont know if it helps performance..but I run them all the time...
hope this helps you out some..I works wonders for me...
oh yeah...diffs front and rear...
#347
#350
no sways bars... hum.
you stay w/ your 10m ride height w/ the gangsta lean and I'll stay w/ my 5.5-6mm w/ the bars. we'll see what works best on the slilck, sealer'd pavement in a few weeks....
#352
So im not the first one to lose them damn small screws Im gonna take my swaybar off more so to shed the extra few grams off the front end. (and im well over legal weight) havent noticed much of a diffrence with the bar but I also just got a new set of tires for the front and rear so it should be fun
#353
Generally, shortening the front link will also help to reduce traction roll, as it will increase camber quick enough to keep the car from rolling over. This comes at the expense of mid corner grip, and the car becomes more reactive. If you're traction rolling, losing a bit of front grip is usually ok though.
The cars traction roll off the rear with jack the gripper a lot since jack usually causes the cars to slide a bit, then catch. It's pretty pronounced on foam tire tc cars. Paragon usually makes the cars roll over off of the front wheels, since it is more of a "sticky" type grip.
#355
Not sure which car/setup Darkside ran..but didn't matter as I won.
5.5-6mm rideheight & swaybars all the way around was the hot ticket. 10mm rh is the slow ticket.
But really w/ the TA tires setup doesn't mean much until you have really worn tires...IMO. I'm not wasting my time tweaking the setup on new tires. The grip difference from new to old tires is so great and you have to keep that in mind when talking about TA stuff.
#356
race may 31
Myron Kinnard #8 40 8:00.163 11.162
Donald Martin #2 39 8:02.132 11.351
race june 14
Donald Martin #3 72 8:02.701 6.143
Myron Kinnard #2 72 8:04.280 6.256 1.579
#357
Traction roll
Hi guys, I started VTA recently and I'm running a TC4 on high traction carpet. Last time at the track I started traction rolling in the sweepers. The car is balanced frt to back and side to side. 1.5* toe out frt, 2* toe in rear, frt springs at 17 lbs, rear at 14.5 lbs, 2* camber all around, 5 mm ride with even droop settings (droop not changed for 3 weeks), 17.5 w/ LRP Stockstar set at 5 and NiMh either 4200 or 4600.
My buddy pointed out a tire coming loose and that's been fixed as well as checking the others. But still traction rolling.
Any ideas?
Any ideas?
#358
Any ideas?
Any ideas?
#359
As for tire compound, I'm using jack the gripper all around with full coverage. Applied anyware from 10 to 15 before the race. I have not changed this since I started, is it wrong?
#360
on of the things you could do to fix your problem ( I had the same) is use Jack on all the rears and only the inside half of the front tires. im guessing your tires are nice and broke in and sticky so you don't need alot anymore on the fronts. with your tire coming unglued the side walls could of been rolling under and turning you over. another thing could be trigger controle. I fould if your lifting too much that the suspension is settleing down to far., Basicly your bottoming out the suspnsion so theres no more flex and the tires end up takeing the full load.if traction is still too much of a problem clean your tires with motor spray, it will dry the rubber and harden the tires. hope this works for you
