Speed Passion brand new Spec Racing LeMans car - The LM1
#767
Hi. The name of the hobby shop is R2 Hobbies HK. Look under Decals and find
WRT Audi R8 Drift Car decals. I thingk they are 11.88 but you will have to wait
about ten days. I will post a photo soon for you. Regards
Norman
On the Top of the page in the search box under accessories for cars look for decals and find the ones for WRT Drift Speedhunters decal set. Attached
photo. Hope this helps. Regards
Norman
Norman
Norman
#768
Norman
Norman
Norman
Norman
#769
Sorry if it has been covered earlier...I am having problems with the steering linkage 'hanging up/getting stuck' when turning. It is getting caught on turnbuckles (see enclosed pic in the red circle area).
Is there a fix or did I mess up something during assembly?
Thanks,
-Rich
Thanks,
-Rich
I added 2mm of shims to compensate for the additional shims I put under the arms.
#770
#771
Thanks,
-Rich
Thanks,
-Rich
Kit height calls for 4mm (2x2mm) shims between the ride height plate and the arm.
For every mm shim you add, simply add that shim also, to the bottom of the steering posts.
All you are doing is keeping the steering system in the same plane as it's default location.
#772
Hey all just putting my car together and wondering if you all sand the center hole of the spur gear to allow the diff to work properly or does it wear in?
Chris
Chris
#776
Is the 10 degree castor block a good starting point as shown in the directions?
Also hit a sticking point with the kingpin pivot balls on the front lower arms. Even without the screws in the arms the pivot balls were not very free. How do you free these up. It binds up the steering.
In the directions they show 3 mm from back of arm to bottom of kingpin for spring load. Picture shows a lot of spring, while reality you see very little spring at 3mm, is this value right?
Cgolf
Cgolf
#777
Cgolf
Cgolf
Those lower pivot balls really are snug. With the ball in the lower arm, slip in the kingpin and press arm to the ball a couple times with a padded pliers. Rotate the ball and repeat a couple times to form the arm around the ball. Another trick is to put a mild abrasive in, like tooth paste and spin the ball in the arm with a hand drill, then rinse and oil with very light machine oil.
Spring preload: Ignore the instructions. Put the king pin in until the spring touches the lower perch and is not floating free. Adjust preload and front droop from there. 3mm is too tight. It should be more like 4mm to start. Droop should be in the .5 to 1mm range.
#778
Run the 5* caster block, all shims back.
#779
things have changed.
so after a recent trip to my local hobby store that advertized they had two carpet tracks .............. ( i took a 4 year hiatus from the hobby been doing this for almost 20 years now)
there i was sitting in a room with about 20 people at benches with all these blinged out aluminum and carbon fiber cambered out plastic wheeled cars.. that slide around at about 2mph .. and im sitting there thinking to my self like .. " so this is it .. this is cool now"..."wow none of these people know how to drive"
there is no scene .. where i live to my knowledge and i want one of these cars to race with in a class so bad
