Castle Mamba Monster + Zippy Lipo's = SMOKED >
Old 05-25-2009, 08:01 AM
  #136
Originally Posted by wrxrocks
Should I cry now. My mamba moster esc just caught fire after only two minutes of running. I just finished converting my Losi Muggy from nitro
And yes i used Zippy (two 3s). But I have been using the same zippy packs with my savage flux for about 20 runs and they have been perfect. I also have use the same packs with my mamba max with 5700kv about 10 runs. So how does CC explain that? I will give them a call soon and hope to get it fix/replace. I think cc must stand by their products. It a good business practice to replace esc instead of losing customers.
What motor? what gearing? thats alot of power, to high kv motor and I could see problems and in a fairly heavy truck, 6s is alot power even with the right motor. just wondering.
jnyrcr is offline
Old 05-25-2009, 01:58 PM
  #137
my gearing is 13 pinion and 44 spure. The motor is 2200kv, that I bought as a combo. There should not be smoke coming out of the esc. I said cc needs to come clean on this matter.
wrxrocks is offline
Old 05-25-2009, 02:05 PM
  #138
Jube's Avatar
Trader Rating: 43 (100%+)
Thank you for my laugh today! If you dont know why you smoked your esc then maybe you should try doing some research before you put your components into service. Amazing that guys like you want to blame castle for your ignorance. Sorry to be so blunt.
Jube is offline
Old 05-25-2009, 03:35 PM
  #139
R40Victim's Avatar
On what was he ignorant?
R40Victim is offline
Old 05-25-2009, 03:50 PM
  #140
drperry's Avatar
3.38 gear ratio is something you see in a touring car...
That's pretty tall... Unless there's a LOT of gear reduction in the transmission/diffs.
drperry is offline
  #141
Jube's Avatar
6s w/ 2200kv in a 12lb vehicle? What part of that combo sounds safe for electronics to you?
Jube is offline
Old 05-25-2009, 04:01 PM
  #142
R40Victim's Avatar
wrxrocks, what vehicle is this in? I'm running a 12/48 in my Jammin truggy, problem free. 13/44 isn't much taller, for an 8th scale buggy/truggy. The stock 8ight E comes with a 2100 Kv motor geared 15/45. So before you guys belittle him, lets figure out where he went wrong, or even if he did. I was beginning to think you guys blamed the failure on his Zippy pack.
Old 05-25-2009, 04:02 PM
  #143
drperry's Avatar
Well... It does... But you need way lower gear ratios...
At least 4... So a 12T pinion and 50T spur.... Preferably the biggest spur and smallest pinion you can get away with.
drperry is offline
Old 05-25-2009, 04:10 PM
  #144
Jube's Avatar
It says in his post his vehicle is a converted Losi Muggy which weighs almost 12lbs. He is running a 2200KV motor on 6 cells. Now to me that is not a safe, reliable combo. At some point we as consumers have got to start taking some responsibility for our actions. When we decide to push the limits then we need to be prepared to suffer the consiquences for such actions and not cry about how CC has not built a good product.
Im really not picking on this one guy here, Im only using him as an example for some of the stupid stuff I've read about, including this episode.
Then again I'm usually an ass that says stuff when I shouldn't so feel free to pass me off as bad gas!
Jube is offline
Old 05-25-2009, 04:18 PM
  #145
R40Victim's Avatar
LOL, I missed that part. I thought we were talking about some other car. The Castle system DOES advertise being for Monster Trucks, so I don't think he was all that ignorant for putting together what he did. And unless the internal gearing for the Muggy is dramatically different than other 8th scales, his gearing wasn't that far off either. True, he should've asked advice before completing it with that gear. But the system is advertised as being able to handle Monster Trucks... AFAIK, most MTs are in that weight range.
You're correct though; I, having researched the HELL outta brushless 8th scale, would've geared much more conservative. But this is relatively new territory we're covering here, so there's bound to be a few hard lessons learned.
Let's just see if we can help him get his investment going again.
Old 05-25-2009, 04:40 PM
  #146
Jube's Avatar
I guess the part that throws the red flag for me is the 6s pack. Thats alot of voltage. I had a 2200 CC combo and that thing was a monster on 4s, cant imagine 6s.
Im done. I shouldnt have said a thing.
Jube is offline
Old 05-25-2009, 06:03 PM
  #147
I guess the part that throws the red flag for me is the 6s pack. Thats alot of voltage. I had a 22oo CC combo and that thing was a monster on 4s, cant imagine 6s.
+1, I'm not an expert on this stuff, but from what I've read it sounds like it needs a much lower kv motor, the esc is rated for 6s, I don't know about a 2200 kv motor.
jnyrcr is offline
Old 05-25-2009, 10:14 PM
  #148
OK guys I take it all back. I just went and recounted my spur gear. It has 46 teeth. I doublchecked. So 13/46 is not tall at all.
if I run 10/46 I don't think it is drivable because 13/46 does wheelie on demand. The stock nitro had never done any wheelie. BTW the nitro stock also run 13/46 and later Losi sells the Muggy with 12/46. I think 13/46 is reasonable. I checked my temp right before the esc smoked/fired up. The motor show about 120 and esc about 100, then two laps later all I see was smoke then fire.
The HPI flux has 44 teeth spur, I was confused.
My point is Zippy is good enough for HPI savage flux with twin 3s. The flux has the same esc as v3. May be I am just lucky with the flux but not with the v3. The two trucks weigh about the same.
I just run a Flux again with twin 3s about 4 hours ago without any problems. The muggy is down but the Savage flux is still going around 60mph. I'll run it again tomorrow with twin 3s and we'll see.
One more thing, the final Front/Rear Differential Gear Ratio is 4.1 to 1 and it has direct drive with center diff.
wrxrocks is offline
Old 05-26-2009, 01:36 AM
  #149
drperry's Avatar
That's odd... It's definitely not a gear issue, with a 4.1:1 ratio... Or, at least, it shouldn't be.
drperry is offline
Old 05-26-2009, 07:39 AM
  #150
R40Victim's Avatar
This is the part with the Zippy Haters come out the woodwork to say, "You foolish cheap battery buying fool!" C'mon, I know you're out there!
