Castle Mamba Monster + Zippy Lipo's = SMOKED
#106
Buy a123 batteries instead of lipos, same power, don't catch on fire and on top of that they learn to balance themselves and don't need to be balanced often and you can actually drain all the power from them. Also they are almost 3 times lighter than actual Lipo's, I use them for those reasons.
#107
It's just harder for some.
#108
now which one?
So which ruddy battery fo i get for my stock standard ERBE that i have coming? I thought zippy was the go! But is this one going to be ok on the standard gearing? Its the 4s1p 20-30c 5000 or should i go with the 3s1p?
hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6351
I only have a couple of true RC 8000mah 10c batts, they are obviously not they way to go! or are they?
#109
Heya,
Good thread, running the zippy 5000mah 4s with MMM and 2200kv, smoked the zippy, but not due to the battery spiking. The tray ripped out and the lipo hit the steering post and shorted. I since created a case to avoid this user error.
As reviewing the hobbycity website I concur on all the positive feedback that is posted there, but I also believe that all of us are running pretty new untested by the masses power systems. By anymeans we may be the Beta testers for some of the companies. I believe Castle puts out a quality product and stands behind it with great service because they know it hasn't be tested in ALL vehicles.
This is why we have the "expert" forum, we try new stuff and we do not test lightly and we take the risk of losing some cash and a car.
My offroad kit now has a welding glove and a nice bucket of beach sand.
Never going nitro...too slow...too messy....too noisy....too expensive....
#110
#112
mine went poof after runing it about 15 times , i was useing brand new smc 5200 2s X2
#113
I have nothing but good to say about Castle. I have never had any of the 1/8 scale motors, but have 4 of the 1/10 systems. Two Mamba Max and two Sidewinders. Never had any problems with ESC's or motors. EXCEPT when I loaned my 7700kv to my buddy and he crashed HARD and broke the pinion shaft off......broke it the F off! Called CC to see how much to fix and they said send it in we'll take care of it. NO CHARGE, NO BS. I'm sure they are working on the issues, but I dont think they are the only one's haveing issues. My buddy had 2 Losi brushless systems in a row that were junk out of the box! First one went about 5 feet and puff of smoke, 2nd one had too short pinion shaft and pinion gear wouldnt even fit on it! He gave up on them.
#114
To the original poster. I was a mechanic for several years before running cranes and the one thing I learned is even with the best quality control it is still possible to get bad/defective parts. Could have been a bad resistor in the esc to begin with or just as easily could have been a faulty cell in the battery. Either way I'm sure castle or anyone else would rather blame another manufacturer than man up and take responsibility for problems. Fact of the matter is if Castle doesnt specifically state NOT to use zippy products than as far as your warranty is concerned they should replace their electronics. On the other hand if you contacted zippy about their battery frying your esc they would similarly argue that YOU had done something during charging or abused the battery in some way. Sorry to hear about your trouble because either company you try to battle it out with will be difficult. I run zippys in my castle products and havent had ANY trouble at all. Batteries work great as do the castle power systems.
#115
CC says those are the biggest capacitors they can put on the ESC.
#116
agreed.. but the point I made before was that I don't think that all Zippys are bad. It appears that QA on these packs aren't as rigorous as other more expensive packs. And therefore have a greater probability of being sub-spec.
If you trawl through this forum and others, Zippys get really good reports, but they seem to get a good number of bad reports too.. This would indicate that when they are good... they're the best bang for buck packs you can get. But conversely, you can just as easily get a crappy pack.
I don't see this trend with the more expensive packs..
#118
This said, I do have a MM in my Hyper 7 and love it. I think Castle makes some great stuff, but it seems they are trying to lay blame somewhere it doesn't really belong, and for a very rare problem. How many others have had something damaged in this fashion from zippy batteries?
They claim the zippy packs are total junk but they are not allowed to say anything to consumers in their packaging.
#119
#120
+1 here I have the SMC 5000mah 28C 2S and it usually takes about 30 min to charge and haven't had a problem yet. Plus the prices are reasonable.
Oh yeah BTW Been nitro and will never go back I like what was said earlier "...too slow...too messy....too noisy....too expensive...."
