Hot Bodies Cyclone
#9243
#9245
Double Post... Delete..
#9246
i got a question for the carpet guys, i built my car a few months ago and havent had a chance to run it on the rug, hows the stock chassis on carpet? or should i get a BMI chassis ASAP..
#9247
for all you racers using the 3racing 18T pulleys..
I found the perfect rear belt.. YOK BD-189L
1 tooth bigger than stock 187mm.
now I need to find a 510mm front belt.. stock is 507mm
soon as I get the new belt tension cams from 3Racing.. hoping it will work and not worry about new front belts...
#9248
Does anybody have a good stock gear combo or final drive ratio to use with the 13.5 GTB brushless?
#9250
is there any batery holder for cyclone...?
#9253
#9255
i am no longer making TC parts because i need to concentrate on releasing and supporting my 1/12th car.i have 2 cyclone carpet chassis kits left that i can give a good deal on.let me know if your interested.these are the only TC kits i have left in stock and i will no longer be producing the kits.
