CRC's New Generation-X.... Your Thoughts?
#1201
i just purchased a brand new gen x last weekend, while trying to fit the right rear wheel bearings on i had a heck of a time, upon inspection i found that the axle has a crack in it and is ever so slightly over size where the threads were inserted, is this going to be a problem?
#1202
#1204
16 is ok bigger is just a waist.
brushed or BL
#1205
Sorry Frank. Jack told me he made them for you.
Just a quick correction here...
Jaco does not make the foam for CRC tires. In fact, I'm very sure that Jaco does not make the foam for Jaco tires. CRC, GRP, Parma, BSR and Jaco all get foam that originates from the same factory in Japan.
CRC pioneered the big wheel craze that has now been "implemented" by every other manufacturer. Our Pro Cuts have won Regional, National and World Championships.
When comparing to other brands, CRC front wheels have a slightly larger OD. It also appears that our wheels are a bit more stiff than the rest. Another nice feature is the design of he rear wheel puts additional bracing around the mounting area. We like to think that this design allows our rear wheels take hit better than other wheels.
With our new, more efficient mounting and truing, a few months ago, CRC drastically lowered the price of the tires to distributors allowing them to sell to the dealers cheaper. We hope that dealers pass this savings on to the final consumer. As tires stock moves through the system, we are beginning to see prices on the Pro Cuts drop to the sub $12 range.
Best tires, great price. But of course I am biased!
Thanks,
Frank
Thanks,
Frank
#1206
#1207
thanks for responding, OD, umm probably met you at nats, i'm a friend of Jb's
#1208
#1209
I just got to say that the more I drive this car the more I like it. Well, I think it is a 1/12th scale thing in general, but this just happens to be the car I am driving. I do have a few questions; my rollout is 40.88mm, tight tech track (40'x60'), Co27 motor comes off the track at 145 F. Good, not good? I am also having problems with the diff, it seems to pick up a lot of carpet and get inside the diff rings sometimes requires a rebuild before the main, but it is something I am doing as others are not having the same problem. Are ceramic diff balls worth it?
#1210
and you only need a little pit of lub on the balls,dont over do it.
#1211
#1212
Where do you get the ceramic balls from? In Mod, I am having to rebuild it every 3-4 runs, I think it's the rings. I can just flip the rings over, and it's good again... In 19T and stock the kit rings/balls hold up just fine. Any input would be appreciated.
#1213
#1214
#1215
Get a http://www.slapmastertools.com/101-1...iff-thrust.php and your diff lasts a while even with the carbide balls.
