Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 10-11-2006, 06:52 AM
  #16336
Alex_kipper's Avatar
hey guys, i was wondering whats the size of the wheel nuts on the car?
i wana order my tool before i get the car
Alex_kipper is offline
Old 10-11-2006, 07:43 AM
  #16337
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
7mm wheel nuts.
Jon Kerr is offline
Old 10-11-2006, 07:55 AM
  #16338
PW
PW's Avatar
Don't get that confused with 4mm thread
PW is offline
Old 10-11-2006, 12:00 PM
  #16339
STLNLST's Avatar
Trader Rating: 32 (100%+)
We have the regionals this weekend so we'll have some good news to repaort after it's all said and done. Weylin almost scared me into retirement....LOL
STLNLST is offline
Old 10-11-2006, 12:06 PM
  #16340
HarshGuy's Avatar
..umm ...I don't think Weylin was the one people were scared of
HarshGuy is offline
Old 10-11-2006, 01:08 PM
  #16341
mattb's Avatar
hi is there any mods the team drivers do to the ec wen they build it to race?
atm i have the carpet shock towers no spacers on the diff/spool/layshaft gear
ceramic berings on the layshaft ti screws and i have the pro 4 shock collers on order is there any more?
thanks
mattb
p.s i feel like this thread is dieing lol so liven it up lmo
oh and i nearly forgot i run 27t stock and i have taken all the belt tensoneres out lol
mattb is offline
Old 10-11-2006, 01:44 PM
  #16342
wyd
wyd's Avatar
Trader Rating: 51 (100%+)
I don't think it is leveling off any. Lots of good info from many of the regulars if you just post to them............they will answer to the best of their knowledge.
I would say that when building the car the first time you should take it slow and make sure it is built correctly the first time. This gives you a good base to make changes off the car if it is built correctly.
wyd is offline
Old 10-11-2006, 02:06 PM
  #16343
matt_h's Avatar
Matt, where did you order the collers from?
i need some
Matt
matt_h is offline
Old 10-11-2006, 03:15 PM
  #16344
Jon Kerr's Avatar
thanks
mattb
What do you mean no spacers on the layshaft/spool? There should be 1 shim on either side of the diff/spool inside of the bearing. The instructions say 2 shims but that'll make it too tight. The shims that go on the ends of the layshaft are needed too. Just make sure everything is built straight, and like wyd said take your time. Also, with the stock CVD's, I'd suggest you rebuild them before you install them to make sure their built right. Use blue thread lock on the set screw and don't tighten down too tight. The coupling being hollow doesn't support the pin as well as the new ones that were just released. So if you over tighten the set screw, it can crack the pin without you even knowing. The CVD will come apart on the track even without hitting anything.
Jon Kerr is offline
Old 10-11-2006, 04:05 PM
  #16345
Skiddins's Avatar
I do use the spacer on the layshaft, but I don't use the shims on the diff at all.
Without them there is 0.15mm of play, the shims are 0.2mm thick, so I haven't bothered.
The last CVD i checked had the grub screw so tight it broke my 1.5mm hex driver
Skiddins
Skiddins is offline
Old 10-12-2006, 06:11 AM
  #16346
STLNLST's Avatar
i need some
Matt
I believe that I got mine from Tower They are a little tight at first but after they break in they're just fine.
STLNLST is offline
  #16347
STLNLST's Avatar
So what are you saying
STLNLST is offline
Old 10-12-2006, 07:19 AM
  #16348
mattb's Avatar
i need some
Matt
ordered from models in motion i belive the no is hp3005 or somthing lol
i have no shims and on the actual diff were the spacers are there is none lol
i dont use any riser plates apart from the whishbone 1's lol
mattb is offline
Old 10-12-2006, 07:31 AM
  #16349
mattb's Avatar
i need some
Matt
just rang up there gettin an order in tommorow so if u order now theyll post tommorow
mattb is offline
Old 10-12-2006, 10:05 AM
  #16350
matt_h's Avatar
Cheers Matt,
Order number is hp30004 if anyone else needs it.
Also found them at kev's racing bits (a little cheaper too)
Matt
matt_h is offline
