3racing F109
#1651
clear nail polish works too--or --you can add some color--and pink is the shizz
#1653
UF1 series
Grand Premio De Caltalunya
UF1 Series this Saturday Orange County California...
Track will be open at 8:30
Qualifying will start at 10:30
Pitting in the grass...
Power supplied, bring extension cord...
more info :
http://uf1series.com/index.html
more info :
#1656
Only issue is that the rear wing is lexan and not a one piece molded unit like f109 wing. So there is no mount just wing. But I used the rear wing from a Duratrax Delphi Indy car. Still need to the side winglets on it. If possible I will yet to use some graphite and build a wing mount to use the proper wing. If not, this will just have to do.
#1657
So all I need is the F104 aluminum diff housing set #54158 and an F104 drive shaft right? Drops all right in?
Looks like I have f-ed up the stock diff somehow.
#1661
UF1 Series
Final race of the 2011 UF1 Season will be this Saturday...
Doors open at 10AM...
#1663
Well the 3Racing F109 and the Tech Racing cars are probably the best chassis right out of the box. But the F109 is too wide to look right for the new bodies made for the F104. This is easily remedied by putting the F104 front suspension on the car and adding F104 wheels and tires. The Tech Racing car is rarer to find in the US so I haven't seen one first hand but it does look like a good chassis. The F104 has the simplest design and pretty easy to start with...upgrade it with the Exotech chassis kit and you'll have a great car. They all are pretty good kits when you get down to it.
#1664
well while Im here, I finally got some Shimizu tires for my Mutant F109K4 ( the F104 front end) Went with the F/R3 softs. Ran it on the carpet today. After I put some Associated hard springs in the front (.024s) and laid down the rear shock to almost level, it was very nice and crisp on the track. Still a tad bit of over steer, but alot of that is due to the new track layout which hasnt been raced on yet. So theres not a good groove. There will be after this weekends racing. Next week I will race it, and my standard F109.
Last edited by texastc; 10-20-2011 at 08:29 PM. Reason: added text, didnt want to make a new post
