Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 08-13-2010, 01:01 PM
  #19366
dizzy1's Avatar
Trader Rating: 29 (100%+)
Korey,
When do you find it best to use the 1.0/1.0 or 1.5/1.5 blocks in the front instead of the standard rear front mount? Is it only for high bite or does it make the car feel odd and you don't use it normally? Also, when you do this does this push the width of the car out to far to meet ROAR specs? DO you then use the thin hexes to get the width in spec?
dizzy1 is offline
Old 08-13-2010, 01:38 PM
  #19367
Originally Posted by tomislav
is there alternative to HB Differential Cup Joint Adapter, it's high price for two and i hope for something cheaper that fit.
thanks
lets try again with to the drivers that did well on race
tomislav is offline
Old 08-13-2010, 08:09 PM
  #19368
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
Originally Posted by dizzy1
Korey,
I use those when grip is very high... usually only on carpet it seems. I use all the standard blocks when on asphalt... usually results in more steering. I still think they are better most of the time.
-Korey
Korey Harbke is offline
Old 08-14-2010, 06:59 AM
  #19369
jag88's Avatar
-Korey
I know this should be asked on the TCX thread but because it was brought up here and I know you use them, was there any provision for running the 1.5/1.5 or 2.0/2.0 front end mod on the TCX ? Are there extra holes and special blocks provided ?
jag88 is offline
Old 08-14-2010, 10:01 AM
  #19370
I'm pretty sure it has the holes (not 100% on that) but the main reason to use the wider blocks before was to lengthen the front camber link beyond what we could before. Now that the TCX has longer links anyway, I don't see it being needed.
But... I'm not 100% sure as I have never run the TCX yet. I'll try it and let everyone know once mine arrives.
-Korey
Old 08-14-2010, 04:18 PM
  #19371
Well guys, after two race weekends on my new POM diff, i find that its not up to snuff for me. i think the alloy diff from the MooreSpeed edition will hold up better. the plastic one has to go
nomaak is offline
Old 08-15-2010, 02:57 AM
  #19372
korey...
recently got a exotek chassis and wondering if i should change anything to accomadate this ?
Currently i run http://www.petitrc.com/reglages/hotb...etup200712.pdf
Im running 13.5t , in cold british weather normally on 27R tyres , I also been running cut top and middle deck
Also my exotek chassis has the holes for the FR and RF mod
madwestmo is offline
Old 08-15-2010, 09:25 AM
  #19373
AGNO's Avatar
I disagree my diff. POM TC is much more resistant of Moorespeed version (at least 10.5)
AGNO is offline
Old 08-15-2010, 09:42 AM
  #19374
AGNO's Avatar
Originally Posted by madwestmo
korey...
I also use EXOTEK chassis and upper deck cut with a very similar setup, only F/R 500cps oil shock (in Italy is very hot right now ...) and this setup works very well without modification FR-RF.
AGNO is offline
Old 08-15-2010, 11:40 AM
  #19375
korey...
You should be fine with that. I run setups similar to that on parking lots a lot! So it should be a decent starting point.
-Korey
Old 08-16-2010, 02:48 AM
  #19376
Just to let everyone know... my Cyclone I ran at the recent nationals is up int he for sale section. Take a look!
Old 08-16-2010, 08:47 AM
  #19377
Trader Rating: 19 (100%+)
Put a link in your post Korey...
Advil is offline
Old 08-16-2010, 09:57 AM
  #19378
2xs
I had to jump on it ASAP. I already have 1 Cyclone TC that I run in 17.5 and I like the setup features of the chassis more than any of the other cars that run in this area.
And the support in this forum is a big plus also.
2xs is offline
Old 08-16-2010, 10:05 AM
  #19379
superspeed's Avatar
is Hara and Moore still with hot bodies racing?
I noticed they weren't in the A-main at the ifmar this year.
superspeed is offline
Old 08-16-2010, 10:26 AM
  #19380
san.'s Avatar
Trader Rating: 61 (100%+)
Hara won TITC 2010 and Andy was 4th at this year's EFRA Championships in France.
san. is offline
