SpeedMerchant X-Ray 12 Conversion >
Old 08-08-2011, 06:10 PM
  #46
JoelV is offline
Old 08-18-2011, 09:13 PM
  #47
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
question it's the conversion kit for the xray 12th scale are longer wheel base or wider than the stock?
OVA is offline
Old 08-18-2011, 10:51 PM
  #48
Johnny Wishbone's Avatar
Both
Johnny Wishbone is offline
Old 08-18-2011, 11:19 PM
  #49
both
JoelV is offline
Old 08-19-2011, 07:57 AM
  #50
OVA
OVA's Avatar
Originally Posted by JoelV
both
How much longer?
it worth to get the conversion over stock?
OVA is offline
Old 08-19-2011, 08:53 AM
  #51
How much longer?
Not only the width and wb are nice changes that settle the car, but all the other changes definately make it a all around worth while change over the stock car.
The upper motor pod plate makes for more space for brushless wires. It also changes the shock mount point which smooths the car and gets the shock more into the proper part of the stroke, not bottomed or toped out anymore.
Changing the tweak springs, taking them off the same point as the link at the back seems to make the car respond better.
The side dampners are much better than the side shock as well.
The whole conversion has really changed the car for the better. BTW Nice job Bruce.
I only hope the WGT kit does the same for the car.
Old 08-19-2011, 10:38 AM
  #52
OVA
OVA's Avatar
I do agreed everything you said.. Thanks
Now has anyones got one running on the carpet track?
OVA is offline
Old 08-19-2011, 11:00 AM
  #53
I've done one run after conversion. This car shows to be very flat, fast transitions, very easy to drive hard. The change in feel from the old car to this one is well worth the money. I usually have limited expectations for first time out test drives, but honestly, this car felt really nice in about 3 laps, and I haven't driven 12th in over a year now. Its a very nice alternative to the other polar battery mount cars. On carpet.
Old 08-19-2011, 11:34 AM
  #54
SpeedMerchant's Avatar
Thanks Driva.
Glad you're having fun.
Honestly, nothing but 100% positive response to the conversion from customers.
Let's start getting some set-ups posted by you fast guys to help the others get going.
Take care.-Bruce
SpeedMerchant is offline
Old 08-19-2011, 12:55 PM
  #55
Andrew Gray's Avatar
Driva!!!
New car looks dialed Bruce. Good work as always.
Andrew Gray is offline
Old 08-19-2011, 01:32 PM
  #56
OVA
OVA's Avatar
Question
Are you running stock or mod 12th?
thanks excellent feedback
OVA is offline
Old 08-19-2011, 01:33 PM
  #57
OVA
OVA's Avatar
Originally Posted by SpeedMerchant
Thanks Driva.
Take care.-Bruce
1+
OVA is offline
Old 08-19-2011, 01:46 PM
  #58
Question
10.5 boosted at the moment.
Old 08-19-2011, 02:53 PM
  #59
OVA
OVA's Avatar
Thanks for getting back to me ..
I have the xray t-bar pan car and what other things or part I needs to get to complete my car?
I still have my old speedmerchant rev 5 ..thnaks
OVA is offline
Old 08-19-2011, 03:25 PM
  #60
From a previous post.
This is what you'll need for a t bar version of the car. Just went through and knowing what you need from an xray 12 link car and what the t bar exploded veiw does not have, I put together the list. I didn't bother with hardware.
XRA373090 pivot socket
XRA371190 side links
XRA303241 pivot balls
XRA376360 Standoffs
XRA373590 plastic spacer
XRA376350 Graphite antenna holder (or not if you don't intend to use normal battery position)
