TC3 Forum
#7891
I found a kit for $40 that has it all. I guess the oversize bit you use for the install is not a problem? Have you tried it on the trans. cases?
#7893
Trader Rating: 51 (100%+)
DaveW Andrew, MikeD, and Craig Xavier are the ones to beat in Modified. Still alot of the same guys that were fast when you went thier are still racing. Those boys in 19 turn where fast to. Stock is now their beginner class and 19 turn is for the big boys and mod is for the insane.
#7894
helicoil
trackdesigner71
A helicoil is a thread repair insert.IT looks kind of like a spring,if you strip a thread out(4-40) you wolud get that size helicoil to repair it . they are sold in kits which come with thread inserts, tap and instalation tool.They work very good.
#7895
Where can you buy them? A link would be great.
#7896
Yeah a link would be great cause i would like to put helicoils in most of the areas in my car. I just dont like the composite wearing out when u take the screws in and out. When u drive like me then u need all the help u can get to get the stuff just to stay together!
Srry for the confusion sns820 is asc # 3875 4-40 11/32.
SpeediePHATT a pic would be great. Thanks for all the replies!
#7897
Re: Kickup
Originally posted by Coxy
How do you achieve negative Kickup (-2) on the front end. Do you put a different block in the front rear or something like that.
Coxy.
Coxy.
Coxy.
#7898
helicoil link
You can get the helicoils from www.mcmastercarr.com They have an instalation tool for $19.27 #930609001
helicoil 4-40x.168(for hubs)#91732a285
helicoil 4-40X.224(tranny cases) 091732a701
you would still have to get a 4-40 tap.This also requires you to drill the hole slghtly larger (there is an exact size not sure if it )so the helicoil can fit an keep it the 4-40 size.there might be kits with everything but I do not know where to get it. HOPES THIS HELPS
#7899
Coxy, if you were to try to use the F-2 block in place of the "F" block, the diff case would hit it, then you would have to dremel the block, and some of the case, and it would be more of a pain than what you would want. Personally, I would just use the stock "F" block, and raise it two white Associated .050 washers(for the rear wheelbase adjustment), along with the F-0 front block. This should give you somewhere close to the -2degrees of kick-up.
#7900
you have to cut .030 off the f+0 Block and then grind down the bumper to get the -2 degrees. You can add a .030 to the F block in the Front rear but that changes all kinds of things on the car.
#7901
Coxy.
#7902
TTT
TTT
#7903
Originally posted by DaveW
Back from the Birds... ALOT of competition! I had a horrible glitch issue through all of my practice runs and my first qualifier, with minor occasional hits during the last two qualifiers. It was really hard to get a clean run! I ran Sportsman 19T with the Epic adjustable 19T motor. I qualified 9th in the B main, a family situation caused me to leave early and had a DNS for the main. The track wasnt too technical, but the amount of grip was amazing... over 10,000 collective laps were run on the first day of controlled practice!! You can imagine the rubber on the carpet. In all my years of racing i have never had to set a car up to get RID of traction!! The track began to deteriorate, and by the first day of qualifying, it was hard on TC and REAL hard on 1/12th scale. By my third qualifier, there were pieces of duct tape on parts of the track where the carpet was worn away!! Mind you, this carpet was installed brand new on Sunday, and worn out in a week! At any rate, the TC3 ran well. I broke only twice during practice, one was a front outdrive, the second was a front arm and hingepin. Not bad for so much fender rubbing there!
Proficar403 was in my main as well, he was two seconds ahead of me, and drove very well all weekend! His TC3 center brace pictured earlier in this thread was sweeeet! Ill see ya at TFB soon!! MikeWebb, it was good to meet you man! I didnt get to watch the mains but i hope you did well! Arvin Nano, good to see you again bro, hope to run with ya again next year! Melvin, all i can say is, thank you for all of your help, it was great to pit/race with you again! Just makes me miss racing with ya all the more... Until next year...
- Dave
- Dave
I need to become a more "cool customer" at my next big race. How easily 26 lap runs can disappear when your body won't stop shaking . I had a great time.
We also figured out how to get the arcor 19s to run in touring. Gear them so outrageously high that you can smell them from the driver's stand! I have never had so little run time left on a pack after running a 19 turn.
Time to start getting ready for asphalt!
-Arun
#7904
Wheel eating lower shock mount
Help!!
My rear wheels are eating into the lower shock mount on my TC3. I'm running Jayco double purples on the rear and seem to have plenty of clearance. There doesn't seem to be any excessive play in the wheel bearings or anything. Seems like the wheels are really flexing in the corners. Is there a stronger wheel/tire that I can buy that is similar in traction to the Jayco? Car is a team car which is a little on the heavy side.
Suggestions????
Jack
Suggestions????
Jack
#7905
Proficar403: Arun, i was glad to see you do so well for your first big race. The jitters go away man! As far as your screw coming loose, i think i would have to give that screw a slow death by rust "execution"... or at least beat it flat with a hammer and use it as weight for next year!! Its always the simple crap that gets us! As far as the "event" on the straight in my last qualifier, my RPM bumper now shows ALOT of BLUE! Back to the "dyeing board". See ya soon for some hot laps!
- Dave
- Dave
