Gear diff leaking >
Gear diff leaking
Gear diff leaking
Old 02-11-2018, 03:07 PM
Default Gear diff leaking
Hello everyone, I I have a 22sct with the 22rtr gear diff. I noticed it was leaking, and it felt gritty, so I pulled it apart. There was only a thin film of oil covering the gears. I have red about these leaking before, and people changing the seals. My question is: what seals do I put in it? does anyone have a part number?
Thank you
kyle_TLRacing is offline
Old 02-11-2018, 03:38 PM
a1
Thank you
check your manual for part numbers you need, would be a good place to start.
a1 is offline
Old 02-11-2018, 03:48 PM
I know the part number for the original seals, but even the new ones leak. I'm looking for the part number of the aftermarket seals
Old 02-11-2018, 04:08 PM
a1
get your part number and enter it into a well known rc website, they will pop up most best options.
a1 is offline
Old 02-11-2018, 04:12 PM
I don't know the part number, that's what I'm trying to figure out. I don't know what aftermarket seals people use
Old 02-11-2018, 05:15 PM
My advice is don't bother. The Losi RTR diff is a leaky thing and another seal won't change this. I recommend getting a decent gear diff. The TLR race diff for the 22 4.0 is what I use in my 22 SCT 3.0 and it is fantastic. Some have used the Serpent gear diff to good effect. They are both expensive but will work and don't leak.
TLR diff = TLR332067
Serpent diff = 500192
cutting42 is offline
