Team Losi JRXS
Originally Posted by steve eaves
Pooky where ya at?Help i need part # for a spool and aluminum battery tray
Battery tray........LOSA4309 In stock at KTHobbies.com as we speak!
The spool is another matter. The Losi spool " pads " are just coarse grit sandpaper cut to the size and shape of the diff rings. You remove the diff balls and glue the pads to the diff rings to build a spool.
OR.................
What i did and ran all last year was to get an old set of diff rings and cut matching slots in each one so that the balls fit into each cut-out. The pads will have some give in a crash and my cut rings will have 0 read ZERO give! To mark the cut outs I just held in place a diff ring on the side of the pulley and marked the square with a Sharpie. I then took the cutoff wheel and cut the blackened areas out. You need to make each opening a lil bigger than your marks so the ball will seat good. Then on either one be sure to tighten it down good. I hope this helps you out Steve-O !
Brant
can someone post a link to the the front end mod i am having troubles finding it
It's on page 346, an excellent guide on making the camber link. it's in 3 parts.
http://www.rctech.net/forum/showthre...page=346&pp=30
Start at the top and work your way down!
Brant
Brant
ahh thank you very much
Brant
Originally Posted by Randy Caster
Losi may be coming out with a replacement for the sandpaper "rings" for spools, I ran the new pieces on Saturday with great results, and no gluing anything together.
Start call'n out some part numbers Brutha!!!! We all gots sum cash dats needs spend'n !!!! lmao
Lets start a list here..........part numbers needed for the:
Aluminum hex's
New spool pads
Cool guy regular plastic arms
Factory molded camber mod
New Rear and Front shock towers
New style inset diff's
NEW REAR MOTOR CAR!!!
Brant
Originally Posted by POOKYT
New spool pads
Or maybe a hydra-drive...hmmm
(I bet a get someone asking what a hydra-drive is )
Trader Rating: 51 (100%+)
Aluminum hex's
Brant
Aluminum hex's
Brant
LOSA9687 Aluminum .195"w (+.030) Wheel Hexes (2) $ 11.99
LOSA9688 Aluminum .225"w (+.060) Wheel Hexes (2) $ 11.99
where can i get a complete set of roll centre shims from
jordan
jordan
jordan
jordan
Randy,
Can you give me an idea where to start gearing wise with the Checkpoint (JRX-S) 19T. Outdoor asphalt. Have you got to run them much? If so how do you like them?
Thanks.....Greg
Thanks.....Greg
I havent really run them too much, probably start somewhere around 40/128 for a good size outdoor track.
