Old 03-27-2006, 06:18 PM   #11206
POOKYT's Avatar
Originally Posted by steve eaves
Pooky where ya at?Help i need part # for a spool and aluminum battery tray
Battery tray........LOSA4309 In stock at KTHobbies.com as we speak!
The spool is another matter. The Losi spool " pads " are just coarse grit sandpaper cut to the size and shape of the diff rings. You remove the diff balls and glue the pads to the diff rings to build a spool.
OR.................
What i did and ran all last year was to get an old set of diff rings and cut matching slots in each one so that the balls fit into each cut-out. The pads will have some give in a crash and my cut rings will have 0 read ZERO give! To mark the cut outs I just held in place a diff ring on the side of the pulley and marked the square with a Sharpie. I then took the cutoff wheel and cut the blackened areas out. You need to make each opening a lil bigger than your marks so the ball will seat good. Then on either one be sure to tighten it down good. I hope this helps you out Steve-O !
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 03-27-2006, 07:27 PM   #11207
rezalb8891's Avatar
can someone post a link to the the front end mod i am having troubles finding it
rezalb8891 is offline   Reply With Quote
Old 03-27-2006, 07:38 PM   #11208
vabroom's Avatar
It's on page 346, an excellent guide on making the camber link. it's in 3 parts.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 03-27-2006, 07:39 PM   #11209
POOKYT's Avatar
http://www.rctech.net/forum/showthre...page=346&pp=30
Start at the top and work your way down!
Brant
Old 03-27-2006, 08:17 PM   #11210
rezalb8891's Avatar
ahh thank you very much
Old 03-27-2006, 09:55 PM   #11211
POOKYT's Avatar
Your welcome!!! If you have any more questions then let us know.
Brant
Old 03-27-2006, 10:18 PM   #11212
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Losi may be coming out with a replacement for the sandpaper "rings" for spools, I ran the new pieces on Saturday with great results, and no gluing anything together.
Old 03-27-2006, 10:39 PM   #11213
POOKYT's Avatar
Start call'n out some part numbers Brutha!!!! We all gots sum cash dats needs spend'n !!!! lmao
Lets start a list here..........part numbers needed for the:
Aluminum hex's
New spool pads
Cool guy regular plastic arms
Factory molded camber mod
New Rear and Front shock towers
New style inset diff's
NEW REAR MOTOR CAR!!!
Brant
Old 03-27-2006, 11:36 PM   #11214
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by POOKYT
New spool pads
Ta hell with them.... I want a "slipper-clutch" style spool....
Or maybe a hydra-drive...hmmm
(I bet a get someone asking what a hydra-drive is )
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 03-28-2006, 06:47 AM   #11215
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
That would be nice. Factory molded camber link mod would be a nice touch as well.
ST Racing Concepts (STRC)
Old 03-28-2006, 06:58 AM   #11216
Aluminum hex's
Brant
LOSA9686 Aluminum .165"w (Stk) Wheel Hexes (2) $ 11.99
LOSA9687 Aluminum .195"w (+.030) Wheel Hexes (2) $ 11.99
LOSA9688 Aluminum .225"w (+.060) Wheel Hexes (2) $ 11.99
Tony Vega is offline   Reply With Quote
Old 03-28-2006, 01:03 PM   #11217
where can i get a complete set of roll centre shims from
jordan
jordys jrxs is offline   Reply With Quote
Old 03-28-2006, 01:31 PM   #11218
jordan
They are included with the pivot mounts.
Old 03-28-2006, 02:15 PM   #11219
Registered User
Yetiman's Avatar
Randy,
Can you give me an idea where to start gearing wise with the Checkpoint (JRX-S) 19T. Outdoor asphalt. Have you got to run them much? If so how do you like them?
Thanks.....Greg
Yetiman is offline   Reply With Quote
Old 03-28-2006, 02:26 PM   #11220
I havent really run them too much, probably start somewhere around 40/128 for a good size outdoor track.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
