STOCK motor forum >
STOCK motor forum
STOCK motor forum
Old 08-05-2002, 08:47 AM
  #706
shrekair's Avatar
Trader Rating: 9 (91%+)
74 ooh wait i mean 63. oops no that cant be right
shrekair is offline
Old 08-05-2002, 11:26 AM
  #707
Pit-racer's Avatar
Anyone have any info on orion core stock motors?They are being used in the regional 9 on-road race in Texas.What are they compared to and any gearing for FDR.
Pit-racer is offline
Old 08-06-2002, 04:55 AM
  #708
sosidge's Avatar
Shrekair - the 28gram figure is the one you want.
sosidge is offline
Old 08-06-2002, 04:57 AM
  #709
sosidge's Avatar
Originally posted by Racin Rev
avoirdupois?
From the french methinks...
"To have the weight" or maybe "to have the peas" - delete as appropriate
sosidge is offline
Old 08-06-2002, 07:05 AM
  #710
shrekair's Avatar
so 16oz = 28.3g ??
shrekair is offline
Old 08-06-2002, 07:09 AM
  #711
Manticore's Avatar
Originally posted by shrekair
so 16oz = 28.3g ??
16oz = approx 0.45kg
Manticore is offline
Old 08-06-2002, 07:49 AM
  #712
shrekair's Avatar
how many grams is one (1) ounce ??
shrekair is offline
Old 08-06-2002, 08:04 AM
  #713
RC Nitro's Avatar
28.53 grams
RC Nitro is offline
Old 08-07-2002, 05:47 PM
  #714
Dragon Slayer's Avatar
Pitracer.....I'll second that question....anybody have any tips on setting up the ORION Core motor for sedan......brushes/springs/+/-...thanks
Pitracer....see ya' there.....
Dragon Slayer is offline
Old 08-07-2002, 06:35 PM
  #715
Regional Moderator
kansasracer's Avatar
Dragon Slayer:
There is a thread about the Core in the Orion Forum. Setups are there...i haven't tried it yet...
kansasracer is offline
Old 08-07-2002, 06:37 PM
  #716
Core Creations's Avatar
Trader Rating: 108 (100%+)
I have had really good results with a Putnam Green shunt brush on the positive with the stock copper spring and the stock(blueprinted) Orion brush on the negative with a green spring. This is the setup I use for sedan.
Core Creations is offline
Old 08-07-2002, 08:57 PM
  #717
Kansas......thanks
Old 08-07-2002, 11:29 PM
  #718
seaball's Avatar
hey can someone tell me the process of how to find the center of the magnetic gap. maybe my terminology is bad, but you know what i'm looking to do. i just don't really know if i've ever shimmed correctly. how is this done?
seaball is offline
Old 08-08-2002, 03:30 AM
  #719
sosidge's Avatar
I'll try my best to explain
Basically, take all the shims off the arm, put it back in the can (with the brushes out), and give it a spin.
When it comes to rest, it should be sitting in the middle of the field.
Then give it a push and a pull to feel which end needs some shims.
Fit shims, and repeat, until you end up with an arm that sits in the middle of the field, with only a tiny amount of play each way.
sosidge is offline
Old 08-08-2002, 08:34 AM
  #720
seaball's Avatar
that makes sense sosidge. it's just difficult cause it seems that the bushing drag leaves the arm at whatever end i accidentally pulled/pushed it to when spinning. i'll try to better my skills. many thanks.
seaball is offline
