Awesomatix A800/A800R >
Like Tree2275Likes
    Hide Wikipost
Old 03-29-2023, 11:28 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800/A800R
Last edit by: hanulec
A800R Released March 23, 2023 with two kit versions, A800RA (alloy) and A800RC (carbon)
Mid Motor Content ---
New Part Releases
  • January 2020 - A800-AM24-20 Servo Holder - combine servo holder and steering holder to one single part.
  • February 2020 - A800-ADC Advanced Damper Cup Set - Reduces the amount of rebuild routines. It offers the possibility to A) remove air and B) add oil into the damper without the need of full disassembling
  • January 2021 - A800-BDL - Body Downtravel Limiter, replaces SPR08
  • March 2021 - A800-P138LFA - 38T Pully Low Friction - For Gear Diff
  • March 2021 - A800-P138S-LFA 38T Spool Pulley Low Friction - For Spool
  • April 2021 - A800-C27MMX - Full Length Top Deck for A800MMX
  • May 2021 - A800-C01MMA Alloy Chassis - Battery position is shifted to the front to achieve a better overall weight distribution. Removes short arm holes. New narrower shape
  • September 2021 - A800-C04M1+7.0 Arm - narrows the track width for lower grip levels
  • October 2021 - AM180EVO Single Bellcrank Steering Update - AM180EVO is a direct replacement for AM180M5
A800MMX and A800MMXA Kit Updates
  • AM152/AM24-8 is replaced by AM24-20 in this kit (UPDATE 08.03.2021)
  • P138/P138S is replaced by P138-1/P138S-1 in this kit (UPDATE 25.03.2021)
  • C01B-X-MMA is replaced by C01MMA in MMXA kit (UPDATE 26.05.2021)
  • AM180M5 is replaced by AM180EVO in this kit (UPDATE 21.09.2021)
Below OLD Rear Motor Content ---
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 03-07-2019, 11:14 AM
  #3946
ntm
ntm's Avatar
Awesomatix does their reputation no favours by including the garbage alloy turnbuckles. Everybody immediately bins those, as they’re fragile as glass.
The p03 kind of needs a redesign as well to be more robust.
And the lack of alloy long arms is a head scratcher.
Great car, but they're really losing market share around here because of those issues.
Dan, nexxus, Ggrant and 1 others like this.
ntm is offline
Old 03-07-2019, 10:51 PM
  #3947
nexxus's Avatar
Trader Rating: 315 (100%+)
Yep they have all but fallen off a cliff here, I think there are 3 of us in WA that still run them not sure beyond that, a lot of the guys who were known Awesomatix runners like Jeffrie Mackey and Glenn Wilson have since changed brands, couldn't tell you why.
I know if I have wanted to sell an Awesomatix it's always been straight on the main for sale boards, as noone on the Australian boards (or facebook pages etc) will even look sideways at them. There's been a used A800 up for $200 for weeks now.
nexxus is offline
Old 03-08-2019, 04:34 AM
  #3948
The Teacher's Avatar
Trader Rating: 62 (100%+)
You guys are joking right? At my track if you don't have an Awesomatix when you hit the rug you might as well stay home.
Jcrowland2 likes this.
The Teacher is offline
Old 03-08-2019, 04:49 AM
  #3949
I'm pretty sure in Australia they run on asphalt 90% of the time.
malkiy is offline
Old 03-08-2019, 08:13 AM
  #3950
Trader Rating: 19 (100%+)
If you want a tank get an Xray T4. The Awesomatix has been plenty durable for me. I have broken a few hubs and bent/broken arms but only after pretty hard hits.
The P03 are annoying but cheap enough to have a few on hand and replace whenever they get the slightest but of play.
Never broke one of the aluminum turnbuckles in the year that I ran them but installed some RCMaker titanium becaue I'm a sucker for bling.
Xpress, Marcos.J, Adam W. and 1 others like this.
iTz Nicholas72 is offline
Old 03-08-2019, 09:25 AM
  #3951
Kodey65's Avatar
My 2019 Season will be with my 800's...it seems that the new xray and bd9 have caught up to Awesomatix.
I will agree 100% with "ntm" above. The original turnbuckles break or bend very easily...the Ti upgrade is a must. While I have no complaints about P03's....what I do think is another mandatory upgrade is getting rid of P13's and upgrading to xray or 3racing ball cups.
After those improvements the 800's become a lot more reliable on the american board tracks.
Kodey65 is offline
Old 03-08-2019, 09:33 AM
  #3952
No problems here
the only upgrade are ti turnbuckles for indoor, like any other TC.
Outdoors stock is fine.
Jcrowland2 and Kodey65 like this.
Al Sodano is offline
Old 03-08-2019, 01:52 PM
  #3953
Trader Rating: 14 (100%+)
Originally Posted by Al Sodano
No problems here
look at the results at the roar nats . I wouldn’t say they have caught up yet
iTz Nicholas72 and Kodey65 like this.
john holmes 69 is offline
Old 03-09-2019, 01:01 AM
  #3954
nexxus's Avatar
Funny because the mod winner at TITC was a T4
nexxus is offline
Old 03-09-2019, 05:53 AM
  #3955
Max won open brushless at the TITC with a Awesomatix...
So what was your point?
Both great cars. Both are capable of winning in the right hands.
silly. Lol.
Old 03-09-2019, 06:11 AM
  #3956
Looks like Awesomatix is doing just fine in the states...
Adam W. and Kodey65 like this.
Old 03-09-2019, 06:33 AM
  #3957
hanulec's Avatar
Trader Rating: 28 (100%+)
And as a FYI... XRay flew in Alex Hagberg to help the team. He has been driving people's cars all week trying to get folks up to speed.
Xpress, tbrymer, !Mad Max! and 1 others like this.
hanulec is offline
Old 03-09-2019, 09:03 AM
  #3958
KE4PJO's Avatar
Awesomatix already has you, so they don't need to fly anybody in....
KE4PJO is offline
Old 03-09-2019, 04:47 PM
  #3959
Xpress's Avatar
When you have the largest payroll and still don't get the job done. Optimized!
Xpress is offline
Old 03-09-2019, 08:00 PM
  #3960
nexxus's Avatar
No denying that Awesomatix still has a strong following in the US, however I was simply making the observation that at least in Australia it's kind of waning. Although that said, RC in general is sort of struggling here of late lots of politics and micromanagement kind of stifle what is supposed to be a fun hobby.
nexxus is offline
