Xray T4 '13
#3076
Hey Guys, Can you use these on the T4??...... Didn't mention it on the description.....Thanks!.....http://www.amainhobbies.com/product_...r-Set-Orange-4
#3078
what do you guys think of this ?
http://www.reflexracing.net/RSD-20mm...T4_p_1735.html
good ? bad ? worth a shot ?
#3079
Refelex Springs....
I ordered them yesterday..... Great line of springs that come out of Reflex.... Been using them on my TC6 and gonna use these on my T4 and there new shorter conversion set-up for the TC6..... Looks like there going to bring out the complete line of carpet springs too.....
#3080
I ordered a few springs Monday.
Some of the asphalt rates seem too stiff for my needs (17.5) so I did
not order the full set.
I also went for the delrin pistons.
Will let you know.
Will let you know.
#3081
Thanks for the link Valls.
#3083
Anyone know what's the extra orange washer is for?
http://www.amainhobbies.com/product_...gs-2-2012-Spec
#3087
+1 Yes they fit I have a set as well. Part numbers are the same
http://www.rc-mushroom.com/product_i...orange-p-22021
#3088
Have a look at my setups for the T4 for Newbury;
http://www.piez0r.com/Skiddins/Xray%...etups/?C=M;O=D
#3089
just need some help with front ride height. I've rebuilt all shocks using 350wt oil and on front using 2.7 spring. I've built all shocks to 57mm long. When trying to set-up front ride height to around 5-5.2mm, I need to wind shock collars nearly all the way down to achieve that height. The collars are about 5.5mm down the shock body.
No such problem with rear shocks.
What am I missing?. I'm running car at base asphalt se-tp, downstops 6mm front, 5 mm rear and 25% rebound.
Any suggestions?
Any suggestions?
#3090
Any suggestions?
Any suggestions?
I run the same springs/droop and it takes me about 4 turns to get to 5mm.
While the car is loaded (battery ect) sit it on a level surface and back out the droop screws. If the front comes up...you found your issue.
If your using droop blocks you need to be checking under the corner of the a arm...not under the knuckle/chub.
If this does not work pull the shocks and check for pin binding.
