Like Tree2Likes
Xray T4 '13
Old 03-27-2013, 07:25 AM
  #3076
artwork's Avatar
Trader Rating: 88 (100%+)
Originally Posted by Kwikvdub
Hey Guys, Can you use these on the T4??...... Didn't mention it on the description.....Thanks!.....http://www.amainhobbies.com/product_...r-Set-Orange-4
Yep you sure can...
artwork is offline
Old 03-27-2013, 07:27 AM
  #3077
Kwikvdub's Avatar
Trader Rating: 100 (100%+)
Thumbs up
Thanks!
Kwikvdub is offline
Old 03-27-2013, 07:37 AM
  #3078
lightfoot's Avatar
what do you guys think of this ?
http://www.reflexracing.net/RSD-20mm...T4_p_1735.html
good ? bad ? worth a shot ?
lightfoot is offline
Old 03-27-2013, 07:49 AM
  #3079
Kwikvdub's Avatar
Thumbs up Refelex Springs....
I ordered them yesterday..... Great line of springs that come out of Reflex.... Been using them on my TC6 and gonna use these on my T4 and there new shorter conversion set-up for the TC6..... Looks like there going to bring out the complete line of carpet springs too.....
Kwikvdub is offline
Old 03-27-2013, 08:24 AM
  #3080
j.d.roost's Avatar
Trader Rating: 32 (100%+)
I ordered a few springs Monday.
Some of the asphalt rates seem too stiff for my needs (17.5) so I did
not order the full set.
I also went for the delrin pistons.
Will let you know.
j.d.roost is offline
Old 03-27-2013, 08:25 AM
  #3081
j.d.roost's Avatar
Must get those.
Thanks for the link Valls.
Old 03-27-2013, 08:34 AM
  #3082
Kwikvdub's Avatar
Thumbs up
Kwikvdub is offline
Old 03-27-2013, 09:07 AM
  #3083
Originally Posted by artwork
what surface and what class (motor) are you running?
Carpet, 13.5 boosted/10.5 boosted
thanks
Nathan Wilson is offline
Old 03-27-2013, 09:12 AM
  #3084
Jerz616's Avatar
Trader Rating: 49 (100%+)
Yep you sure can...
Are you sure they fit. I thought the T4 was a larger dia spring then the T3.
Jerz616 is offline
Old 03-27-2013, 09:30 AM
  #3085
artwork's Avatar
I have a set of them on both of my T4's...yes they fit just fine
artwork is offline
Old 03-27-2013, 09:31 AM
  #3086
cyba888's Avatar
Anyone know what's the extra orange washer is for?
http://www.amainhobbies.com/product_...gs-2-2012-Spec
cyba888 is offline
Old 03-27-2013, 09:38 AM
  #3087
cyba888's Avatar
+1 Yes they fit I have a set as well. Part numbers are the same
http://www.rc-mushroom.com/product_i...orange-p-22021
cyba888 is offline
Old 03-27-2013, 01:13 PM
  #3088
Originally Posted by Skiddins
Have a look at my setups for the T4 for Newbury;
http://www.piez0r.com/Skiddins/Xray%...etups/?C=M;O=D
you seem to always prefer the 1mm inner front and 0mm inner rear camber link positions, whys this have tried running them higher? what difference does it make?
Old 03-28-2013, 11:58 PM
  #3089
aussierevo's Avatar
Trader Rating: 14 (100%+)
just need some help with front ride height. I've rebuilt all shocks using 350wt oil and on front using 2.7 spring. I've built all shocks to 57mm long. When trying to set-up front ride height to around 5-5.2mm, I need to wind shock collars nearly all the way down to achieve that height. The collars are about 5.5mm down the shock body.
No such problem with rear shocks.
What am I missing?. I'm running car at base asphalt se-tp, downstops 6mm front, 5 mm rear and 25% rebound.
Any suggestions?
aussierevo is offline
Old 03-29-2013, 05:28 AM
  #3090
j.d.roost's Avatar
Any suggestions?
Something is either binding or put together wrong.
I run the same springs/droop and it takes me about 4 turns to get to 5mm.
While the car is loaded (battery ect) sit it on a level surface and back out the droop screws. If the front comes up...you found your issue.
If your using droop blocks you need to be checking under the corner of the a arm...not under the knuckle/chub.
If this does not work pull the shocks and check for pin binding.
