CRC 1/10 Pan Car >
CRC 1/10 Pan Car
Like Tree3Likes
CRC 1/10 Pan Car
Old 07-11-2009, 08:47 PM
  #961
Trader Rating: 16 (100%+)
Originally Posted by higbo
Improve the performance of car?
For me...yes...the Xray shock is an improvement.
The Losi shock really wants to be built with only one o-ring. This means more servicing to keep it performing properly for the Gen-X 10.
Recently built some high end Tamiya 415/416 shocks for my Corally Phi TC car. Have to give them an A+ rating (on my Phi); but, I can buy Xray shocks in sets of two as opposed to four for the Tamiya units.
Bill
Still Bill is offline
Old 07-11-2009, 10:55 PM
  #962
espresso1967's Avatar
Trader Rating: 18 (100%+)
Reason for that was that they were defected. It was a known issue at CRC and even spoke to them. They have new ones with better bonding that are not separating. If you have a receipt for any of these axles they will replace them with the newer ones just released.
Originally Posted by mikel33
Careful with those lock nuts. I've seen several CRC axles have the threaded rod pulled right out of the axle.
espresso1967 is offline
Old 07-12-2009, 12:50 AM
  #963
NiMo's Avatar
Note taken.
I had had one go on the track, think the tread had been weakened cos it just gave out under power whilst on a new FTD pace, fortunately my previous time took me to pole.
Love this car with 2s 13.5, good speed and drivability.
Top 15 from SuperPole after last meeting:
(this would be the final grid if all classes ran as one)
1 … Glen Westwood … 10.5 … Schumacher … 21 310.56 … 14.42
2 … Jay Westwood … 10.5 … Schumacher … 21 310.81 … 14.46
3 … Ori Sohachevsky … 10.5 … Schumacher … 21 314.38 … 14.57
4Nigel MossGT1 … Calandra … 20 303.24 … 14.80
5 … Tim Langdell … 10.5 … Schumacher … 20 303.67 … 14.81
6 … Jamie Vassallo … 10.5 … Schumacher … 20 304.35 … 14.89
7 … Mark Payne … 10.5 … Xray … 20 307.05 … 14.88
8 … Scott Hauser … 13.5 … Xray … 20 312.08 … 15.38
9 … Dominic Skinner … 13.5 … Tamiya … 20 312.31 … 15.35
10 … Tony Foster … 10.5 … Xray … 20 313.26 … 15.23
11 … Mark Payne … GT2 … Xray … 20 314.87 … 15.45
12 … Nick Upton … 10.5 … Xray … 20 315.36 … 15.37
13 … Gerald Page … GT2 … Associated … 19 300.23 … 15.33
14 … Neil Hunt … 10.5 … Schumacher … 19 300.50 … 15.49
15 … Jamie Gill … 13.5 … Yokomo … 19 301.26 … 15.42
NiMo is offline
Old 07-12-2009, 12:56 AM
  #964
NiMo's Avatar
Bill
I built my shock as it came, so cant remember if it were 1 or 2 rings.
Have some Kyosho Teflon coated shocks from my now retired Nitro car, may look at using one of those if it can give even more rear bite.
NiMo is offline
Old 07-12-2009, 02:56 PM
  #965
Ok re-buidling now but I am not getting any rebound on the shock. I have installed the o-ring properly, shaft is in nice a snug. I know it has been a while since I first built the shock but just want to make sure that it should have rebound?
Old 07-12-2009, 03:11 PM
  #966
NiMo's Avatar
I was always lead to believe that a shock should not have any rebound.
It is a damper, not a spring, and its job is to slow down the movement of the moving part, in this case the whole rear motor pod.
but i will stand to be corrected if wrong.
NiMo is offline
Old 07-14-2009, 08:14 AM
  #967
Fabricio's Avatar
Default Shock angle
What does afect on the car changing the angle of the shock?
Fabricio is offline
Old 07-14-2009, 02:51 PM
  #968
It changes the spring rate at the axle. The more angled the shock is the softer it will be at the axle. The dampening will be softer too.
Shawn.
Shawn68z is offline
Old 07-14-2009, 03:19 PM
  #969
Fabricio's Avatar
Shawn.
Shawn, translating it to the track a more angled shock is going to be more softer so in a bumpy track would be better?
Fabricio is offline
Old 07-14-2009, 04:20 PM
  #970
I have some great news for Southern California residents. New asphalt track just opend up yesterday. My pan car was hooked up all day today and will be making this home base from now on.
Check it.
http://www.westcoastrcraceway.com
15905 Canary Ave. La Mirada, Ca. 90638
+ YouTube Video
+ YouTube Video
Old 07-14-2009, 04:26 PM
  #971
P.S. for anyone wondering the SMC 5200mah 40c fits in the gen x 10. A bit tight but fits right in no modifications. Had a 30 minute run and was the first time running this battery. Now compared to the Yea Racing 3200mah 20c what a huge difference
Old 07-14-2009, 04:42 PM
  #972
Also for those of you that convince me not to sell my pan, THANKS A BUNCH. This is one bad ass car on the right track.
Old 07-14-2009, 04:44 PM
  #973
tallyrc's Avatar
Trader Rating: 12 (100%+)
i had two extremely fast drivers from the florida state series running my car last night with 17.5 2s lipo, and you should have seen the smiles... everyone that runs it, loves it..
tallyrc is offline
Old 07-14-2009, 09:18 PM
  #974
We knew you would cave...LOL
Old 07-14-2009, 09:42 PM
  #975
Changed my mind on this tonight. I was at the track for practice tonight, as was playing around with the center spring. Going lower made the spring seem harder.
Becuse the motor pod is mounted by the football, the pivot is at that point. So when the pod pivots, the shock mounting point doesnt only move forward but moves in the downward direction. That downward movement is inline with the travel of the shock absorber, making the spring move more for the amount of axle travel (higher wheel rate). So making the shock parrallel to the ground would make it seem softer.
Shawn
Shawn68z is offline
