HPI R40 Nitro Car Forum
#4276
Originally posted by HarKonnenD
I think this is it. That's all thats on the webpage.
http://www2.towerhobbies.com/cgi-bin...?&I=LXGWX3&P=Z
#4278
The 4 gear diff binds up more when torque is applied to the diff. So it basically increases the stiffness of the diff compared with the 2 gear diff given the same diff oil weight.
#4279
THANKS EVERYONE!!!
I got 3rd place on the first hit, then on the second hit I got 1st. place, on the 3rd hit I had problems with the steering, aparently there are 2 nuts, one on each side that tend to get stuck an I couldn;t get my car to turn left, but in the end I got second place overall and that was good enough for me.... Thaks everyone for all your help...
One question. I run on pavement and I'm using still the stock tires for my R40. What kind of tires should I use foam or rubber? I ordered some ellegi racing 35s, but I dont kow if rubber works better on pave?
#4280
Originally posted by KLANDERMAN
THANKS EVERYONE!!!
THANKS EVERYONE!!!
#4281
I'll do that...
I was reading about the 4 gear case for the traction, but got confused, is the one mentioned a stock one, or is this an optional part for the R40? I've seen the one mentioned at towerhobbies, ut it looks stock. The one I want is aluminum and its at r/c mart, if you wanna check it out i'll send you the link.
#4282
I'll do that...
I'll do that...
#4283
http://www.rcmart.com/catalog/produc...oducts_id=7253
If the above link doesn't work, try this...
The home page is www.rcmart.com , go to parts, select Gp, then pick the HPI r-40 and select the brand three racing, they have many optional parts here... the rear casing is on the second page... good luck!
#4284
When I was putting together my R-40 I saw the option to put a 23T or a 22T on the large belt. What does this do? Whichone is better?
#4285
Changing the pulley gears on the large belt allows you to change the amount of front wheel overdrive. This is something that I will be experimenting with as well. Since you have two gears 22/23T(front shaft) and 18/19T on the rear shaft, you can experiment by changing these around to different configurations.
Keeping in mind that a smaller diameter gear provides "increased rotation speed" compared to a larger diameter gear you can experiment. Let me know how you like it.
#4286
Actually thats how I've benn using it, It handles well, but I still have to try it with the 22 T to see what changes...
Did you check out th aluminum casing?
#4287
#4288
Well mostly with rocks and debri, they get stuck in there and disfigure the casing, making it imposible for the belt to be tight. That's basically the reason why I went ahead and ordered the aluminum, but the one I ordered is for the front. Let's hope I don't regret it later...
#4289
Has anyone used the Trinity wasp engine? It's a big block .12 turbo.
#4290
belts
speakin about belts being tight....has anyone seen those orange looking fiber belts, ive seen them on g4's, i was just wondering if anyone makes them for the r40, cuz mine stretch really easily and come off, especially the side belt
thanks
thanks
