Old 01-16-2005, 06:14 PM   #4276
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Originally posted by HarKonnenD
I think this is it. That's all thats on the webpage.
http://www2.towerhobbies.com/cgi-bin...?&I=LXGWX3&P=Z
This is the stock diff gear set... I thought you found a light-weight aluminum version of this somewhere... sorry, my misunderstanding.
JAG Racing is offline   Reply With Quote
Old 01-16-2005, 07:33 PM   #4277
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Ohh no. I just heard from an HPI guy that a 4gear diff in the rear offers more stable traction under accelerating.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 01-16-2005, 07:38 PM   #4278
AMGRacer's Avatar
The 4 gear diff binds up more when torque is applied to the diff. So it basically increases the stiffness of the diff compared with the 2 gear diff given the same diff oil weight.
AMGRacer is offline   Reply With Quote
Old 01-17-2005, 08:12 AM   #4279
KLANDERMAN's Avatar
THANKS EVERYONE!!!
I got 3rd place on the first hit, then on the second hit I got 1st. place, on the 3rd hit I had problems with the steering, aparently there are 2 nuts, one on each side that tend to get stuck an I couldn;t get my car to turn left, but in the end I got second place overall and that was good enough for me.... Thaks everyone for all your help...
One question. I run on pavement and I'm using still the stock tires for my R40. What kind of tires should I use foam or rubber? I ordered some ellegi racing 35s, but I dont kow if rubber works better on pave?
KLANDERMAN is offline   Reply With Quote
Old 01-17-2005, 08:17 AM   #4280
JAG Racing's Avatar
Originally posted by KLANDERMAN
THANKS EVERYONE!!!
Typically rubber works on concrete and foam works on asphault. You might buy some 35/37/40 combinations to help tune your car better.
Old 01-17-2005, 08:21 AM   #4281
KLANDERMAN's Avatar
I'll do that...
I was reading about the 4 gear case for the traction, but got confused, is the one mentioned a stock one, or is this an optional part for the R40? I've seen the one mentioned at towerhobbies, ut it looks stock. The one I want is aluminum and its at r/c mart, if you wanna check it out i'll send you the link.
Old 01-17-2005, 08:25 AM   #4282
JAG Racing's Avatar
I'll do that...
The Tower one is the stock differential gear set. Please paste the link when you have time - THanks.
Old 01-17-2005, 08:31 AM   #4283
KLANDERMAN's Avatar
http://www.rcmart.com/catalog/produc...oducts_id=7253
If the above link doesn't work, try this...
The home page is www.rcmart.com , go to parts, select Gp, then pick the HPI r-40 and select the brand three racing, they have many optional parts here... the rear casing is on the second page... good luck!
Old 01-17-2005, 10:25 AM   #4284
KLANDERMAN's Avatar
When I was putting together my R-40 I saw the option to put a 23T or a 22T on the large belt. What does this do? Whichone is better?
Old 01-17-2005, 11:20 AM   #4285
JAG Racing's Avatar
The front wheels and rear wheels rotate at slightly different speeds. Typically most 4WD cars have the front wheels turning lsoghtly faster than the rears.
Changing the pulley gears on the large belt allows you to change the amount of front wheel overdrive. This is something that I will be experimenting with as well. Since you have two gears 22/23T(front shaft) and 18/19T on the rear shaft, you can experiment by changing these around to different configurations.
Keeping in mind that a smaller diameter gear provides "increased rotation speed" compared to a larger diameter gear you can experiment. Let me know how you like it.
Old 01-17-2005, 11:22 AM   #4286
KLANDERMAN's Avatar
Actually thats how I've benn using it, It handles well, but I still have to try it with the 22 T to see what changes...
Did you check out th aluminum casing?
Old 01-17-2005, 01:15 PM   #4287
Rapid Roy's Avatar
An aluminum dif case and gear will probably add quite a bit of rotating mass. The picture also doesn't show the internal side so I'm not sure if it will accept the 4 gear conversion. Reducing rotating mass is half of the purpose of the .8 pitch 2 speed, so adding weight to the rear diff probably wouldn't be your best choice. Are you having problems with the stock case and gear?
Rapid Roy is offline   Reply With Quote
Old 01-17-2005, 01:48 PM   #4288
KLANDERMAN's Avatar
Well mostly with rocks and debri, they get stuck in there and disfigure the casing, making it imposible for the belt to be tight. That's basically the reason why I went ahead and ordered the aluminum, but the one I ordered is for the front. Let's hope I don't regret it later...
Old 01-17-2005, 01:56 PM   #4289
KLANDERMAN's Avatar
Has anyone used the Trinity wasp engine? It's a big block .12 turbo.
Old 01-18-2005, 02:23 PM   #4290
Send a message via AIM to goldenboy
Default belts
speakin about belts being tight....has anyone seen those orange looking fiber belts, ive seen them on g4's, i was just wondering if anyone makes them for the r40, cuz mine stretch really easily and come off, especially the side belt
thanks
goldenboy is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
