Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#1471
Hi Paul
What setting you run on speedo LRP SXX TC version 2.?
I run motor X12 5.0T and speedo SXX TC version 2 with software 1.5.
What you recommend setting.?
Thank
Thank
#1472
It depends on the size of the track but if i put in a 5.0 100ft track i would start at 2,2,3,4 and go from there. Thanks!
#1473
Hi Paul,
What servo do you use in the T3'12?
#1474
Hi Paul,
What FDR and motor timing to run on medium sized asphalt track for boosted 10.5? I'm running tekin rs btw.
#1475
Paul,
How should I set the expo on my flysky radio so that my 17.5 speed passion motor and orion esc can power my yokomo to a race win? Oh, and what springs should I run on the back of my bd-5?
#1476
Hi, with the servo saver i would use the short case 9551, if you want to use a straight servo horn you will have to use a bigger servo.
Hi. This is just a guess but if i had to go run boosted 10.5 right now i would start with a 7.0-7.2 overall ratio, 20deg timing then play with the boost settings while monitoring the temp..
hopefully its not that far off for you.
Wish i could help kev.
#1477
Hi paul...
Your awesome!
GO GRAVITY RC!!! !
-Alex W.
PS.
I would love to go on Doug Hays track at LiveRC..too bad its a couple hours away ! I still don't have a LiveRC account ugh...no $$$ right now, spent it all on books for the semester hahaha!
Your awesome!
GO GRAVITY RC!!! !
-Alex W.
PS.
#1478
[QUOTE=Paul L;10218898]Hi, with the servo saver i would use the short case 9551, if you want to use a straight servo horn you will have to use a bigger servo.
What do you mean by a straight servo horn? Do you use a straight servo horn? What servo do you use?
#1479
Trader Rating: 32 (100%+)
#1480
see ya.
[QUOTE=gonzo416;10226497]
Im confused. maybe you should just call me. you have so little words that appear to mean so much.
#1482
#1483
It totally depends on the traction level of the track, for really low bite i have no problem running shock fluid, even 300 or 400, for med bite i will normally run 1k diff fluid, for high bite i usually end up at 2000, for super high traction i will go as high as 3000. It has become for me a huge tuning option to make the car drive properly and be predictable. If it is too thin the car drives funny and if it is too thick the car drives funny but in a different way, but for me it is all about following the traction with the diff oil.
"ahhh birds", "thirteen twwwwwooooooo". slightly curled shaking index finger, "Revenge is a dish", Kosovo, fruit punch. etc etc. lol
#1485
Why do i want no part of this? lol. its normally about once a year that you guys find the time to bait me in to getting heckled. so maybe i can help.
