Like Tree3Likes
Tamiya TRF415
Old 08-20-2006, 12:08 PM
  #15166
m3ndo5a's Avatar
Thanks Ed....I did not break in the car I normally do (wish full thinking)... and I will back off the tension and see what happen from there....as well as tooth down....
m3ndo5a is offline
Old 08-20-2006, 12:42 PM
  #15167
alan1467's Avatar
Default Belts
Anyone have problems with the belts stripping? I did 3 rear and one front today in 7 races Even with new pulleys it still took the teeth off them. I was not the only one atleast another 5 or 6 people stripped atleast one or more. I was running a 9x1 Checkpoint at Carlisle buit I've had them go at other tracks, maybe the belt are not upto the power were using now
Alan
alan1467 is offline
Old 08-20-2006, 12:56 PM
  #15168
Ballsie's Avatar
Alan,
I kept breaking belts in stock, spec and mod - that's probably the main reason I went to the Cyclone.
Are you using the new pulleys on the MRE?
Ballsie is offline
Old 08-20-2006, 01:17 PM
  #15169
alan1467's Avatar
Originally Posted by Ballsie
Alan,
I've used both STD pulleys, TA05 ones and the new MSX-MR ones with all the same problems. Maybe trying Cyclone belts may help?
alan1467 is offline
Old 08-20-2006, 01:27 PM
  #15170
TRF415boy's Avatar
What I did is simple: I had specific pulleys made up. 18T centre pulleys and I use longer belts. You can get similar size pulleys now from tech racing (TA05 low gear ratio conversion kit ref TTA180) but for the belts you'll either have to contact me or find them yourself.
TRF415boy is offline
Old 08-20-2006, 01:51 PM
  #15171
TryHard's Avatar
really don't know how/why people struggle with belts (and this isn't a flame against anyone who has)... Ive been running a 415 for over 2years now, mostly with the white belts, and in the whole time I've done one rear belt...
TryHard is offline
Old 08-20-2006, 02:37 PM
  #15172
TRF415boy's Avatar
Yes but you mostly run 27T indoors and 19T outdoors, you're not putting any stress on your belts. Now bolt a mod in and we'll see...
Old 08-20-2006, 03:03 PM
  #15173
TryHard's Avatar
Not in entire agreement, ran one set of belts the whole year so far... not had any problems... and thats 19t.. pretty good in my book.
TryHard is offline
Old 08-20-2006, 05:20 PM
  #15174
The Teacher's Avatar
Trader Rating: 62 (100%+)
Wow, this is the first I've heard of people having problems with the belts on the msx. I've run stock and 19t on carpet with foam tires and my belts look like new...??? ...and I run the TAO5 diff pulleys/center pulleys...
The Teacher is offline
Old 08-20-2006, 11:47 PM
  #15175
I think this had been said before but if you are chewing up belts in less than 10 runs in stock or 19 turn you need to check the centerpullies, they are proberly worn out. A worn out centerpulley destroys a belt in no time.
Mr_Orange is offline
Old 08-21-2006, 03:06 AM
  #15176
Must be running the belts too tight, maybe they are rubbing on the battery bars or something. Running stock and 19t they should last for years. Mod is a different matter and if you got the money to run mod then you can afford lots of belts
jnrtin is offline
Old 08-21-2006, 08:58 AM
  #15177
Does anyone have any insight on new short arms vs. old 414 arms on carpet? Whats the most consistent?
alien too is offline
Old 08-21-2006, 01:24 PM
  #15178
jakster's Avatar
i am a newbe to the 415 i have a few questions about setups
i have 3 total- 2 msx & 1 ms. i am looking for a good strating piont for stock and a 19 turn set up both on asphalt smooth med to high grip. a see a lot of set up sheets but very few for front diff set up, what have you guys found best for suspension blocks ff fr fr rr ??? any help will be great! i really like the cars they a so smooth to drive, just need to find a fast set up to starting point! i am running the rev arms on one and lw on the others.
jakster is offline
Old 08-21-2006, 02:30 PM
  #15179
TRF415boy's Avatar
Rev arms and LW are the same
for asphalt get yourself a spool and put the stock MSX setup it works very well.
Old 08-21-2006, 06:17 PM
  #15180
TacticalTimbo's Avatar
Default Newbie
Hi,I've just bought a new stock Tamiya TRF 415 chassis after coming from a TL-01, so completely new.
Man I’ve got so many questions:
My first Q is what motor pinion should I use, I've got a 13X3T motor?
Second does anyone know if I can still use my Futaba s3003 steering servo, if not what should I get?
My third Q is do they make a battery clip for the TRF 415 cos I don't want to waste my money on tape that'll run out!
Lastly do all 190mm shells fit the TRF 415?
an answer to any of these would be greatly appreciated.
TacticalTimbo is offline
