Serpent 710
Originally posted by InitialD
I think Michael put the weight there to balance the chassis.
To just put the weight there to balance the chassis is not advantageous enough ... you've seen Ray Wood's video ... the track is so rough (as well as high speed) that I think the 710 handles fine without being perfectly balanced. My 2 cents' worth.
Re: Re: Re: a water snake!!!!!
If I'm not mistaken, that's a recent photo of Paul Knapton's 710.
All I am saying is real petty incident.
Originally posted by KevinS
Air? No... I'm not THAT stupid... I use helium!
So with Holland through, you went head banging session the rest of the weekend?
Re: Re: Re: Re: a water snake!!!!!
Originally posted by Palmaris Europe
Yep. Hard to make out the silver with the reflection from the rain. Unfortunately I believe he was disqualified from that event after dominating and winning the A Main.
Well, I actually happened to browze the recent setups on mytsn. And the name of the JPG file gave the clue away. So much for the RING.
Well, car is built, BUT, this morning, two of my shocks was almost emty of oil. I can see under the car, that it has leaked out.
Any cure for this?
Any cure for this?
Any cure for this?
Any cure for this?
Cheers, MArk.
Pipe repair and protection
Hi S710 drivers!
On this weekend I have damaged my exhaust pipe from the side.
My budy has ran in to me from the side and it was my fault cause I hade a spin.
The pipe is squashed from the both sides. it is Nova Mega 2171.
Can I drive with pipe in this condition?
How can I repair that?
Has anybody done some protection around the pipe?
Any pics would be nice ...
Thanks a lot
Thanks a lot
Re: Pipe repair and protection
Originally posted by lagnaf
Hi S710 drivers!
Thanks a lot
Hi S710 drivers!
Thanks a lot
Cheers, Mark.
PS: I've never tried this, but others guy here have.
Re: Re: Pipe repair and protection
Originally posted by markp27
I know some guys fill the exhaust with water, blocking one end, and then place it in the freezer - the expanding nature of water when it freezes pushes out the "dents". But keep a careful eye on the pipe in the freezer - don't just leave it there or else it may split.
Cheers, Mark.
Cheers, Mark.
Will try this today
But how can I block the water 100%?
I think the Ice pressure will push the blocade out!
Cheers, Ognjen
Re: Re: Re: Pipe repair and protection
Thanks for this advice
Will try this today
Cheers, Ognjen
Will try this today
Cheers, Ognjen
Cheers, Mark.
Re: Re: Re: Re: Pipe repair and protection
I don't think you have to block the pipe 100%, just enough so the water doesn't run out before you put it in the freezer. And, like I mentioned, I believe you should leave one end open (i.e. the end which fits onto the manifold) otherwise the pressure is too high. Keep checking the pipe in the freezer often to ensure that it doesn't go too far.
Cheers, Mark.
Cheers, Mark.
Will do so!
Can you tell me what is this guy put around the exit end of the pipe? This grey stuf what is this? It should make this litlle exit pipe more stable.
Cheers, Ognjen
Re: Re: Re: Re: Re: Pipe repair and protection
OK
Will do so!
Cheers, Ognjen
OK
Will do so!
Cheers, Ognjen
Strange that it is so quiet here today normally there are a lot more users online and posting - is InitialD ill?
Re: Re: Re: Re: Re: Re: Pipe repair and protection
If I'm not wrong that is the Mother Serpent from Pyramid - it looks like some kind of putty around the pipe and it will certainly be to strengthen the tail pipe.
Maybe they all have a hard weekend behid them and need a few days of rest.
I hope that Pyramid will post what is this putty around the tail pipe.
Where the hell is InitialD i hope his allright.
Will post the pictures of my car and the repaired pipe if it sucseed.
Thanks for help Mark
Re: Re: Re: Re: Re: Re: Re: Pipe repair and protection
Realy strange
Realy strange
Good luck with the pipe.
Cheers, Mark.
OK
Will do so!
Cheers, Ognjen
OK
Will do so!
Cheers, Ognjen
