SC10 Thread
Old 12-04-2011 | 06:58 PM
  #8326
bds81175's Avatar
Moderator
Originally Posted by Zac_with_no_K
Does anyone use outerwears or chassis covers??
Just want to know if I should get one and how well they work?
I've got a JConcepts cover for our outdoor track which is pretty dusty/dirty. Fit is decent and its velcroed in place so its fairly easy to use. Our indoor local track is much tidier and doesn't need the cover. On a cleaner track they are just kind of a pain.
bds81175 is offline
Old 12-04-2011 | 08:25 PM
  #8327
Originally Posted by savannahmick
I have a couple questions I have had a SC10 for about 7 months and my Reedy 3300kv motor died but not sure why I have always checked temps. Anyway is there any chance AE will help me out with this issue? I also bought a new gear diff complete kit but there was no sun gears in the package and all the gears are different now so couldn't use any of the others had to reuse my old gears! Anybody else ever had stuff missing and I really don't know if it's worth the hassle to get some new ones from AE and try to get a new motor or not? I am just curious how AE is about support. Thanks for any info!
Savannahmick & Coxmaster........ call ae and talk to their service/repair dept. They have taken very good care of me when I have called. Good luck.
Murray100 is offline
Old 12-05-2011 | 08:41 AM
  #8328
Numburn's Avatar
I've got one but never use it. The only time I would pull it out is if the track had standing water on it and honestly I'd just assume not be on it.
Numburn is offline
Old 12-05-2011 | 02:33 PM
  #8329
Bretmd94's Avatar
Originally Posted by kbr
im new to offroad an i need alot of help have a sc10 ft with the same setup with slicers on front an calibers on back the track i race on is the worst track to drive no traction an ive got caught up to the top runners but now they want help me get better they just say drive i need some ideas to try next time on the track like setup wise i need alot more traction and speed
Copy the pro's setups
http://www.teamassociated.com/setupsheets/SC10/
Bretmd94 is offline
Old 12-05-2011 | 07:57 PM
  #8330
njnewc's Avatar
Default Maintenance
What maintenance are you guys doing after a race weekend. I feel like I need to do more. I am checking/adding fluid in the shocks every race night, I rebuild when they start leaking or not preforming. I check the ball diff after every race, I take it apart and check for grooves in all the washers about once a month. I only rebuild or change bearings and washers when needed... I check all nuts and bolts after a night of racing. Other than that I don't do much, Granted I keep it pretty clean all the time, so I am assuming this helps. Are you guys oiling anything, CVA's, bearing, motor, etc... If so with what and how often. Thanks for any and all info,
Tim
njnewc is offline
Old 12-05-2011 | 09:09 PM
  #8331
brent701's Avatar
Tim
I clean it. Go over the screws and nuts make sure they are tight. Clean the tires apply Tire Tweaker to the tires. I check the axle drive pins(I have broken a few of them) I check the rims for cracks. I have found one cracked already
I readjust all the suspension settings. I have found through out a night my buggy and truck will change a lot after a night of racing. one night the truck went from -1 camber to =3 camber
brent701 is offline
Old 12-05-2011 | 11:59 PM
  #8332
hey guys, sorry to ask, but i bought the swaybar set, just wondering how it attaches to the shock tower? the picture doesnt really tell me
RoBB is offline
Old 12-06-2011 | 04:37 AM
  #8333
Hey guys- looking for more low-speed, off-power steering.
Where should I go? Front camber link?
OnlyVees is offline
Old 12-06-2011 | 06:32 AM
  #8334
Numburn's Avatar
A quick and easy way would be to get lower caster blocks. You can also slide your pack to the front. It's hard to really discuss camber links without knowing the whole setup.
Numburn is offline
Old 12-06-2011 | 06:39 AM
  #8335
racer1812's Avatar
Super Moderator
You should see a small half round groove with a small screw hole beneath it on each side (front side of the tower). Bar lays in the groove and is held in with a small button head screw and washer.
racer1812 is offline
Old 12-06-2011 | 08:38 AM
  #8336
Point taken. How will adding washers to the front camber link affect handling? ie raising the roll center at the shock tower...
OnlyVees is offline
Old 12-06-2011 | 09:37 AM
  #8337
skengines's Avatar
Do you guys reuse your slipper hubs? If so do you just sand them down?
skengines is offline
Old 12-06-2011 | 09:44 AM
  #8338
Wild Cherry's Avatar
The slipper disks can get too hot , grooved & scratch up ..
Replacement is the best way to fix, sanding the coating off will not work..
* slipper pads can be sanded clean to perform like new .
Wild Cherry is offline
Old 12-06-2011 | 10:14 AM
  #8339
Asharus's Avatar
To those who have glued the servo saver down, any problems with it coming apart? I only ask because I stripped the plastic the servo saver nut holds on to so I had to leave the spring out so I can reassemble it.
I was playing around with it because I had a nasty on power push on the truck which I've never had a problem with, ever. I checked the steering and it had a lot of give, even with the nut all the way down, so I CAd the servo saver together. Now it's beautiful, just worried that it could come apart with a good hit.
Asharus is offline
Old 12-06-2011 | 10:15 AM
  #8340
Tim
I usually wash my pit towel. I will also take a quick look for anything obvious that is loose or out of place. I am finely getting consistent lap times. The more I tinker the less consistent I become. When I notice changes to the drive of the truck and the track hasn't changed much I start looking for any problems. I am now starting to make changes/adjustments to decrease lap times. This works for me and may not be the best option for you.
Mark
mark in wi is offline
