RC10B4.1 FT/WC
Old 11-22-2011 | 09:35 AM
  #7741
Wild Cherry's Avatar
Originally Posted by kyle3333
What is the benefit of running a shorty pack? More specifically a Reedy #306. I understand there are greater tuning capabilities, but the pack is much lighter so that will have to have some kind of effect on the car. Looking at the latest AE setup sheets, the guys running the shorty packs haven't really added anymore weight than normal.
The main benefit using a short pack is you can pack all the electronics centered or inline on the chassis for better balance...
Wild Cherry is offline
Old 11-22-2011 | 10:24 AM
  #7742
jirish617's Avatar
so im going to ask a dumb question, but bare with me, this is my first car that im building. I am noticing on all the setup sheets, for the suspension, it says limiter. what exactly is the limiter? where can i get them? sorry for the stupid question, still learning things
jirish617 is offline
Old 11-22-2011 | 10:59 AM
  #7743
kyle3333's Avatar
Ok, so other than pure weight distribution, there is no real benefit to running a pack that is 105g lighter, because it simply weighs less, correct?
kyle3333 is offline
Old 11-22-2011 | 11:02 AM
  #7744
most people are adding weight as it is...
gguertin145 is offline
Old 11-22-2011 | 11:33 AM
  #7745
T-BirdJunkie's Avatar
Originally Posted by B4power
Got a quick question.
What grease do I put on the gears in the transmission?
ThunderbirdJunkie runs his gearboxes like he runs his women.
Dry.
Originally Posted by Jake S
hows that promatch shorty? if you have even ran it yet?
Dunno yet. Just put the car back together after being stagnant in 2w mod for a while. It no longer has a Novak Cyclone or a 14x2
Originally Posted by TravisS27
He offered!! I thought he was joking. It's not a factory team...but its not a strike either!! LOL I guess he wanted it for his son.
Still stealing
ThunderbirdJunkie bought his shorty because of fore/aft adjustability. Left/right balance isn't all that important...our cars are underweight with LiPo batteries anyway, so you might as well ballast the light side if it really bothers you.
The limiters go inside the shock, underneath the piston's bottom E-clip. They're basically little plastic washers.
ASC4187 is the part number per the manual
http://www3.towerhobbies.com/cgi-bin...?&I=LXPA19&P=7
The purpose is to limit downtravel which limits body roll.
T-BirdJunkie is offline
Old 11-22-2011 | 11:37 AM
  #7746
kyle3333's Avatar
Exactly, that is why I'm a little confused. Running a full size lipo pack is already on the lighter side, so putting a short pack in seems kind of odd. But, there are at least 3 AE drivers testing this. They don't say anything about adding weight to compensate for the short pack. They are just mentioning the weight that is normally added to a modern B4.1 +8mm car.
Yokomo's new 2wd, offers this configuration as well, but none of the cars in the press photos show the electronics on the center line. They simply show one car with a standard size pack and one with a short pack with the electronics in the traditional locations. The only benefit they mention, is greater tunability. So again, you have more weight distribution options, but the car is still over 100g lighter in general.
My hypothesis on the whole matter comes down to the latest trend in 2wd. The longer chassis design. TLR, Associated, Durango, and now Yokomo all subscribe to the longer chassis design concept. Coincidentally, at the same time, short battery packs are being tested in all of these cars. Short battery packs were none existent until longer chassis began to pick up steam, for example the TLR 22. This makes me think that when running a longer car, a shorter battery pack may be more ideal, because of the way the chassis reacts to that particular amount of weight. A sweet bi-product of this, is that the driver has more options for weight distribution.
I don't know, I could be totally wrong about this. It just seems odd to me that 4 company's(that we know of) within the last 10 months have not only started using longer chassis, but shorter battery packs to go with them without any weight compensation.
I am not an engineer, I am just speculating. That is all.
kyle3333 is offline
Old 11-22-2011 | 12:05 PM
  #7747
brent701's Avatar
I think the point to put everything in the middle ESC etc. Is to center the weight. I had to add 1/2 oz on the right side to make up for the ESC. inthe end it's more weight than really needs to be there. Having the weight center and rear helps traction which we seem to have a hard time getting
I don't see a point to add weight to balance the buggy out of the weight is not really needed if you can run a shorty pack and move the weight to the center.
brent701 is offline
Old 11-22-2011 | 12:09 PM
  #7748
ANiznik's Avatar
u can make your buggy as lightweight as u like, but at the big races u will still need to make weight! so if your allready under weight with a standard size batt, u will be adding alot of weight if your using a shorty pack!! it does allow for alot of tuning options though with weight distribution
ANiznik is offline
Old 11-22-2011 | 01:06 PM
  #7749
kyle3333's Avatar
That all makes sense to me, but I have yet to see a B4.1, Durango, or Yokomo run the ESC on the center-line with a short pack and you would still need to add a ton of weight to then be legal. I like the idea of centering everything, but where do you add the weight back? There car seems like it would be such a hand full, a perfectly balanced hand full, but a hand full none the less.
kyle3333 is offline
Old 11-22-2011 | 01:54 PM
  #7750
brent701's Avatar
That's a good point. I know a lot of people switch over to run saddle packs in the SC10 4x4. Does it really make that big of a difference? Who knows. I guess the same applies to the shorty pack on the Buggy.
But with the main weight centers at least if you need to add weight you can add it evenly throughout the buggy. Sides, rear, front. I am sticking to my stick pack it does just fine for me,
brent701 is offline
Old 11-22-2011 | 03:30 PM
  #7751
idrummerboy13's Avatar
can somebody explain what moving the ball stud out on the shock tower does? then moving it to the middle hole on the castor block like brent theike setup...
i am guessing it is an in between from the inner shock tower hole inner on block and inner on shock tower and middle on blocks?
even the rear he moved the holes one over on the hubs and u brace...??
idrummerboy13 is offline
Old 11-22-2011 | 03:38 PM
  #7752
RCmayor's Avatar
I just switched to the hex front conversions and have a question. I bought the new jconcepts nuts for the front they are serrated and I am using the de wheels. I don't have enough room for any socket to fit around that nut without hitting the wheel in the front... Rear ones have plenty of room.
Is there a special tool for this, I see the jconcepts nuts have indents around them? What is everyone using for the front wheels?
Thanks!
I had the opposite problem. The AE front hex wheels didn't have a problem but the Losi 22 rears I couldn't fit a nut driver in. I ended up grinding the JC serrated nuts down to 5/16". It wasn't hard to do, just grind away the high spots on the hexes then go a little more and it is right at 5/16".
RCmayor is offline
Old 11-22-2011 | 06:06 PM
  #7753
derekbsmith's Avatar
Originally Posted by idrummerboy13
with a robinson pinion the silent spur gear is LOUD. it is a brand new setup on both, mesh is perfect lol. Kinda sounds cool though
so what brand of pinion do you all recommend with the jc silent spur gear?
derekbsmith is offline
Old 11-22-2011 | 06:14 PM
  #7754
i usually use gold pinions, they dont make em anymore but i find losi ones are nice and the steel robinson racing not aluminum sound good
Old 11-22-2011 | 06:35 PM
  #7755
Jake S's Avatar
i usually use gold pinions, they dont make em anymore but i find l&*# {edited for language} ones are nice and the steel robinson racing not aluminum sound good
i agree i like the L*#^ pinons too.
Jake S is offline
