RC10B4.1 FT/WC
Old 11-22-2011 | 12:36 AM
  #7726
Guest
Default short lipos
did someone outlaw the short liops?
LOSIRACER77 is offline
Old 11-22-2011 | 12:52 AM
  #7727
T-BirdJunkie's Avatar
ROAR just outlawed chassis that only allow you to fit short LiPos, because that wouldn't allow you to run stick packs.
T-BirdJunkie is offline
Old 11-22-2011 | 01:12 AM
  #7728
Guest
so no more of the losi mid motor right ???
Old 11-22-2011 | 01:37 AM
  #7729
Mid motor can fit saddles or a shorty either one. The way ThunderbirdJunkie interprets it, is it can fit saddles, a shorty, or a stick pack. Saddles only are fine, but if it will only fit a shorty, then it's illegal.
Old 11-22-2011 | 05:23 AM
  #7730
B4power's Avatar
Got a quick question.
What grease do I put on the gears in the transmission?
B4power is offline
Old 11-22-2011 | 05:58 AM
  #7731
Jake S's Avatar
yeah i believe even if the mid motor ONLY fit shorty its still a legal chassis because rear motor fits sticks too. and therefore you could run a shorty in mid motor if it was the only thing that fit.
i believe the rule is there to just keep companies from making additional battery sizes specific for there cars, like AE releasing a b5 that accepted a 80mm battery only, and that reedy just happens to make this new 80mm battery.
Jake S is offline
Old 11-22-2011 | 06:03 AM
  #7732
From the sticky "How To Properly Build And Break In a Ball Differential and Slipper Clutch" thread:
No grease. Just a few drops of 50 wt shock oil.
LD50 is offline
Old 11-22-2011 | 06:32 AM
  #7733
Oso Negro's Avatar
you are 100% right!
Per Steve Pond, current president of ROAR, all current Chassis are legal. The tlr22, even in mid motor, can accept a saddle pack so it is a legal configuration.
keep in mind everyone. This new rule is temporary. There are plans to draft a new standard for shorties that will lift these limits eventually.
Oso Negro is offline
  #7734
Jake S's Avatar
Here's the car:
hows that promatch shorty? if you have even ran it yet?
Jake S is offline
Old 11-22-2011 | 07:21 AM
  #7735
kyle3333's Avatar
What is the benefit of running a shorty pack? More specifically a Reedy #306. I understand there are greater tuning capabilities, but the pack is much lighter so that will have to have some kind of effect on the car. Looking at the latest AE setup sheets, the guys running the shorty packs haven't really added anymore weight than normal.
kyle3333 is offline
Old 11-22-2011 | 07:43 AM
  #7736
TravisS27's Avatar
You should feel bad. That's like stealing
Nice trade!
He offered!! I thought he was joking. It's not a factory team...but its not a strike either!! LOL I guess he wanted it for his son.
TravisS27 is offline
Old 11-22-2011 | 08:11 AM
  #7737
t0p_sh0tta's Avatar
I'm in love. Need to buy 2 more, and convert everything over to shorties.
t0p_sh0tta is offline
Old 11-22-2011 | 08:49 AM
  #7738
I just switched to the hex front conversions and have a question. I bought the new jconcepts nuts for the front they are serrated and I am using the de wheels. I don't have enough room for any socket to fit around that nut without hitting the wheel in the front... Rear ones have plenty of room.
Is there a special tool for this, I see the jconcepts nuts have indents around them? What is everyone using for the front wheels?
Thanks!
gguertin145 is offline
Old 11-22-2011 | 09:09 AM
  #7739
Kyle Wilson's Avatar
Thanks!
Use a bench grinder or a dremel to grind down the O.D. of the socket till it fits or try a Hudy nut driver, they have a thinner wall for tight areas.
Kyle Wilson is offline
Old 11-22-2011 | 09:32 AM
  #7740
Wild Cherry's Avatar
Use the clear Silicon diff lube , other stuff can ruin your diff by contaminating the diff lube...
Wild Cherry is offline
