AC Adapter for Transmitter?
I'm pretty sure that most radios cut the input from the charge jack when you switch the power on. That said you would have to wire a 9.6 DC adapter to the radio's battery input. If the radio has a TX battery pack with a jack then it's easy, just wire the adapter to the correct battery plug. If the radio uses a battery holder then you would have to solder the adapter to a spare battery clip.
